need input on building an engine
Old Jan 26, 2004 | 06:06 PM
slammin86's Avatar
Default need input on building an engine
I blew a hole in my #3 piston on my b16 in my 99 civic si. I currently have 8 psi, and plan to go to 10 by the time this is said and done. I want to build up the bottom of my engine so that there is no possibility of this happening again, but I dont know a lot about what stuff I need. I want to keep this as cheap as possible. Can I get some suggestions on what I need and what brands to go with?
Thanks in advance
Old Jan 26, 2004 | 06:11 PM
redboost10's Avatar
Default Re: need input on building an engine (slammin86)
i also burnt my 3 piston with nos. no wonder why they say egt in #3. haha
Old Jan 26, 2004 | 06:13 PM
B17aTrbo's Avatar
New User
Make sure that the "cheapest" way is the right way! Talk to earl...get you some pistons, rods, sleeve it...do you know why you blew a hole in the piston at only 8psi?
Old Jan 26, 2004 | 06:16 PM
m R g S r's Avatar
Default Re: need input on building an engine (B17aTrbo)
I just blew my motor last week also, but I'm actually happy about it, b/c now I get to build for 500whp. I am probally going to go with AEBS sleeves and move on from there.
Old Jan 26, 2004 | 06:17 PM
rondigs's Avatar
Sleeves is a little much for 10psi. However, if your rebuilding the same block, you may not have a choice. CP pistons, crower or manley rods, and some tuning would be ideal for you (tuning be the key word).
BTW, prior to breaking the engine, what fuel setup/engine management were you using?
Old Jan 26, 2004 | 06:26 PM
B17aTrbo's Avatar
New User
Default Re: need input on building an engine (rondigs)
Sleeves won't hurt even at 10psi...besides, he won't stay at 10psi...cp pistons, crowers or pauters are good too...if you are going to do it might as well go overboard..hehe
Old Jan 27, 2004 | 03:03 AM
slammin86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rondigs &raquo;</TD></TR><TR><TD CLASS="quote">Sleeves is a little much for 10psi. However, if your rebuilding the same block, you may not have a choice. CP pistons, crower or manley rods, and some tuning would be ideal for you (tuning be the key word).
BTW, prior to breaking the engine, what fuel setup/engine management were you using? </TD></TR></TABLE>
I was runnin the vafc hack with 440's and a wideband. I think detonation got me.
I am gonna go hondata first thing
Old Jan 27, 2004 | 05:56 AM
viprcr1's Avatar
some people don't have 900 bucks to waste on going overboard.
Old Jan 27, 2004 | 06:31 AM
B17aTrbo's Avatar
New User
Default Re: need input on building an engine (viprcr1)
Sleeving block= waste? Haha...would be more of a "waste" to pull the motor twice...all I'm saying is if you have the motor pulled then might as well sleeve it...I can't think of a reason why you wouldn't. Can you?
Old Jan 27, 2004 | 06:54 AM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B17aTrbo &raquo;</TD></TR><TR><TD CLASS="quote">Sleeving block= waste? Haha...would be more of a "waste" to pull the motor twice...all I'm saying is if you have the motor pulled then might as well sleeve it...I can't think of a reason why you wouldn't. Can you? </TD></TR></TABLE>
How about money? If you're not going to run at a level where sleeving would be absolutely necessary, spend the money you just saved on tuning.
Old Jan 27, 2004 | 07:09 AM
slammin86's Avatar
Default Re: need input on building an engine (dtmamg)
How much does sleeving the block normally cost?
like i said, i have no intentions of going over 10 psi....i just want to do the bare minimum to be safe cause money is a major issue here
Old Jan 27, 2004 | 07:43 AM
B17aTrbo's Avatar
New User
I think I paid like 950 to get my block sleeved...I wasn't going to do it at first but a talked to earl on a whim and decided I wanted to do it...I'm glad that I did too...
Old Jan 27, 2004 | 12:05 PM
slammin86's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B17aTrbo &raquo;</TD></TR><TR><TD CLASS="quote">I think I paid like 950 to get my block sleeved...I wasn't going to do it at first but a talked to earl on a whim and decided I wanted to do it...I'm glad that I did too...</TD></TR></TABLE>
but it wouldnt really be a must for only 10 psi right?
Old Jan 27, 2004 | 12:09 PM
len's Avatar
len
82mm sleeves, that's what I would do.
TurboGSR96
Feb 22, 2006 05:48 PM
94si94cx
Apr 7, 2004 06:29 AM
Smokin_Joes_2kSi
Mar 7, 2002 12:41 PM
