Should I listen to JOTECH??
Old Jan 25, 2004 | 10:29 AM
Rod.'s Avatar
Default Should I listen to JOTECH??
I am sending my block off to the earl . I called jotech, asked for a price on pistons and some rods. I want to do 83mm on a ls block. They said to do a compression of 9:5 on the pistons. Would that be a good compression ratio or go lower? The ls is like 9:2, also I am shooting for like 350 whp or more .
What does a 83mm on a ls block bring it out to, is it still a 1.8 liter?
What are some good rods other than eagle?
Old Jan 25, 2004 | 10:31 AM
b00sted93Hatch's Avatar
Default Re: Should I listen to JOTECH?? (redturbocivic)
9:5 is fine. 83mm brings it to a 1.9l. As for rods Pauter are GREAT
Old Jan 25, 2004 | 10:39 AM
twkdCD595's Avatar
Default Re: Should I listen to JOTECH?? (allMotor93Hatch)
9.5:1 is fine, tuned well... tuning is key.
Old Jan 25, 2004 | 11:02 AM
Mase's Avatar
Default Re: Should I listen to JOTECH?? (twkdCD595)
if you are going to maximize power, 9.5:1 is fine, just gotta be be well tuned.
Rod.'s Avatar
I searched, found out step decked blocks and o-rings blocks are basically the same. That they both seal good. Their has to be a difference between them. I want to know what which way I should go...step deck or o-ring???
One more stupid question....one a scale of 1-10.. What is your rating on putting a block together if it is your first time. WHat are the pros and cons?
darkdemon215
Mid-Atlantic (Sales)
11
Jun 6, 2007 07:31 PM
eag36
Aug 13, 2005 10:22 PM
S@nt0s
Apr 30, 2005 06:43 AM
BlkslowCRX
12
Feb 9, 2005 10:18 PM
