Broken plastic connector on Injectors. still salvagable?
Pins are fine but the plastic housing that locks the harness connector to the injector is broken. What do you guys think? salvagable? Just tape the connectors together will work good enough? Trying to consider whether to buy some injectors that has this damage becuase it's a lot cheaper.
Re: Broken plastic connector on Injectors. still salvagable? (2000Accord5sp)
I'm sure if your intuitive you can make it work, but if the connector is broken I would wonder if there was any other damage.....
Re: Broken plastic connector on Injectors. still salvagable? (genop)
It was torn off of a JDM engine. You know how they take those engines out. Very rough. However, the guy selling them tested the currents and they all come out right so I would assume there isn't any other damage. I think the only damage happened because someone tried to take it off by force and broke off the plastic part.
