b16 ecu on ls motor
Old Jan 27, 2004 | 08:12 AM
psycho_civic's Avatar
Default b16 ecu on ls motor
i have a 00 si with a b16 that recently messed up. im swapping it out with a 00 ls engine and want to know if my current ecu (p28 chipped ecu with b16 program to run 450's and timing retard) will work fine on my ls engine. or will i need to re-chip the ecu?
Old Jan 27, 2004 | 09:42 AM
Sohc Driver's Avatar
Default Re: b16 ecu on ls motor (psycho_civic)
you'll need to rechip the ecu....i actually think you'll hit fuel cut at 5500 with the b16 ecu if you run it on the LS.
Khoi
Old Jan 27, 2004 | 12:45 PM
bump bump bump
Old Jan 27, 2004 | 01:18 PM
sparkz's Avatar
You'll be able to use a ROM for the P74/P75 LS ECU and plug it directly into your P28.
1994delsolLS
Mar 26, 2009 03:10 AM
v8 integra
12
Nov 10, 2008 11:41 AM
allnaturalb16
Jan 14, 2007 04:02 PM
HondaTeg95
Sep 28, 2005 07:42 PM
LS_racer
Mar 11, 2002 10:05 PM
