TURBO instal problem!!!!!!
Old Jan 25, 2004 | 02:34 PM
airwalk07143's Avatar
Default TURBO instal problem!!!!!!
i have been having problems do my oil return line for about 2-3 weeks now. i know there is millions of threads on this. My problem is that i am goin to use 1/2 hose for my return and run it from my t-25 turbo to my d16z6 oil pan. but i only need the hose to drop about 2 1/2 in and go in about 5 in. but all the fittings i have seen wont work.... most of the fittings are to long..... a 45 deg. fitting drops the hose to low but a 90 deg does drop the hose enough. i know this is tough to understand but if any one could help me i would apprec. it alot.
Old Jan 25, 2004 | 02:51 PM
99B16Si's Avatar
i dont understand what your saying. plus making a return line isnt that complicated just make sure its going up and down and the spout on the oil pan is up high enough not to get back up from oil in the pan. take pics and youll get more help
Old Jan 25, 2004 | 03:00 PM
tilt's Avatar
Default Re: TURBO instal problem!!!!!! (airwalk07143)
You can try clocking the t25 so the drain fitting gets raised up a bit. And you can try drilling the drain fitting on the oil pan a bit lower.
MalcolmV8
Dec 5, 2011 05:29 PM
chris3385
Jan 30, 2010 09:12 PM
Type-ARR
Nov 8, 2007 04:22 AM
torr
Apr 14, 2004 07:48 AM
wade
Jan 7, 2004 12:46 PM
