oil pump/water pump for boost?
Old Jan 26, 2004 | 10:33 AM
jDMJeRk's Avatar
Default oil pump/water pump for boost?
i have a b16 im building (just like you read in everyone of my posts) and i want to make sure i upgrade/replace the oil and water pumps. What is a good one to use; Dont ppl use a gsr or an ITR one because they are more powerful...or something thanks again guys
Old Jan 26, 2004 | 10:34 AM
Flamenco-T's Avatar
Default Re: oil pump/water pump for boost? (jdmjerk)
Use Type R or GSR oil pump, they seems to flow better than the LS or the non vtec version. You cna use either water pump, but for whatever pump you're using, use the same timing belt.
stan
Old Jan 26, 2004 | 02:10 PM
jDMJeRk's Avatar
Default Re: oil pump/water pump for boost? (Flamenco-T)
Im guessing the itr pump is probably more $$$; are they they the same as the gsr?
And wow i didnt know i had to get a certain timing belt; THANKS BIG TIME
say the itr one is 50 bucks more is it going to be worth it or should i just go for the gsr one
Just to be safe; I need the timing belt to match the water pump, that is all that matters? Correct?
Old Jan 26, 2004 | 02:52 PM
len's Avatar
len
1996+ Integra share the same oil pump. 15100-P72-A01. $90.08 + Shipping.
Water Pumps are different. LS vs GSR vs ITR.
Old Jan 26, 2004 | 04:16 PM
turboteg2nv's Avatar
Default Re: oil pump/water pump for boost? (len)
QUOTE=len]1996+ Integra share the same oil pump. 15100-P72-A01. $90.08 + Shipping.
Water Pumps are different. LS vs GSR vs ITR.[/QUOTE]
So if I have a 96 LS, upgrading the oil pump doesn't matter?
Old Jan 26, 2004 | 06:48 PM
len's Avatar
len
Default Re: oil pump/water pump for boost? (turboteg2nv)
No, if you had a pre-OBDII Vehicle yes. The updated oil pump is listed above. Now ITRs do have better water pumps.
Old Jan 27, 2004 | 12:02 AM
jDMJeRk's Avatar
now Im confused
All 96+tegs all have the same oil pumps BUT the ITR?
but the water pumps are all different as well
sounds like i want a ITR water pump and ITR oil pump?
Old Jan 27, 2004 | 05:12 AM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjerk &raquo;</TD></TR><TR><TD CLASS="quote">now Im confused
sounds like i want a ITR water pump and ITR oil pump?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">1996+ Integra share the same oil pump. 15100-P72-A01. $90.08 + Shipping.
Old Jan 27, 2004 | 07:38 AM
earl's Avatar
Hey Len, how come the 94-95 oil pumps are so much more expensive than the 96-up pumps?
BTW, thanks for the great service.
I buy all my OEM stuff from Len's dealership..
Old Jan 27, 2004 | 07:49 AM
Nid Styles's Avatar
Default Re: oil pump/water pump for boost? (earl)
What's the actual difference between the water pumps? I'm assuming since o said use the right belt that means the drive gear must be different, but what else.
Old Jan 27, 2004 | 07:53 AM
b18bturbo's Avatar
Default Re: oil pump/water pump for boost? (nd_styles)
the ls uses the 19t version and gsr./typer r use the 22t version
Old Jan 27, 2004 | 08:22 AM
google's Avatar
Default Re: oil pump/water pump for boost? (b18bturbo)
Old Jan 27, 2004 | 08:28 AM
99B16Si's Avatar
also make sure the year of the oil pump matches the year of the timing belt cover your using or else the bolts wont line up
Old Jan 27, 2004 | 09:41 AM
4-banging's Avatar
Default Re: (99B16Si)
is this information correct for all B-series? or just the B18's? Representing the B16's
Old Jan 27, 2004 | 09:42 AM
b18bturbo's Avatar
Default Re: (4-banging)
same for b16s they use the same parts.
Old Jan 27, 2004 | 10:37 AM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Hey Len, how come the 94-95 oil pumps are so much more expensive than the 96-up pumps?</TD></TR></TABLE>
Honestly Earl, they only thing I can think of is that Honda switched to a different supplier, thus the cheaper price.
Old Jan 27, 2004 | 10:42 AM
b18bturbo's Avatar
Honestly Earl, they only thing I can think of is that Honda switched to a different supplier, thus the cheaper price. </TD></TR></TABLE>
I just upgrade to the new gen one and leave the CYP sensor alon and use new covers its cheaper that way.
Old Jan 27, 2004 | 10:45 AM
99B16Si's Avatar
i dont think the actual 96-up pumps are the same. i think its just the replacement part for those motors
KdF
Mar 10, 2009 05:36 PM
bankhead83
Jun 9, 2005 05:41 PM
kobeRy_si
Jun 6, 2005 03:11 PM
rafiq7
Nov 2, 2004 11:41 AM
Charlie Moua
Mar 27, 2003 10:47 AM
