Safe and correct cr for a built b18c
Old Jan 25, 2004 | 11:35 AM
TRM04's Avatar
Default Safe and correct cr for a built b18c
I need some assistance please...
I am sending my block out to RS Machines for a resleeving, honing and reassembly. I am re-using my Crower rods and installing new Arias pistons. My goal is for 300whp on a EMS system. It's definatly an acheivable goal but the catch is I'd like to have a final cr ratio of 10:1. The head will remain stock. Is 300whp at 10:1cr on an EMS system safe? This is to remain as a street car only with a T3/TO4E turbo system for the power. I hope to be able to run around 10-12psi to acheive the 300whp. Is this safe?
Thanks!
Old Jan 25, 2004 | 12:29 PM
99B16Si's Avatar
youll be prefectly fine. just use a conservative tune on pump gas(a little extra fuel and conservative timing). race gas is a different story
Old Jan 25, 2004 | 03:07 PM
TRM04's Avatar
Default Re: (99B16Si)
Thanks. One important factor I forgot to mention is that it is being bored to 83mm as well. Trying to also achieve as close to 2.0 liter as possible. Does that make a difference?
Old Jan 25, 2004 | 03:55 PM
len's Avatar
len
Default Re: Safe and correct cr for a built b18c (TRM04)
I'd advise you to do some more research on sleeving before you have it done.
That CR is as safe as the tune.
seanclark
Dec 28, 2011 10:34 AM
b18muoio
Sep 9, 2011 12:33 PM
crashsvg
Jan 12, 2010 09:10 PM
reignofchaos
Nov 10, 2003 05:02 PM
Drew Peacock
Jul 29, 2003 03:57 AM
