Engine rebuilders help !!!! piston clearance
Old Jan 28, 2004 | 03:14 PM
Cyber ITR's Avatar
Default Engine rebuilders help !!!! piston clearance
i have a set of JE pistons , currently rebuilding my engine
on the spec sheet, its says to set it to .0040 , but my engine rebuilder told me i would probably need more clearance , cuz i told him i wanna run 30psi and aiming for around 500whp
any idea how much clearance i should use ???
thanks guys !!!!!!!!!!!!
Old Jan 28, 2004 | 03:41 PM
GRTechnologies's Avatar
Default Re: Engine rebuilders help !!!! piston clearance (Day Walker)
are you asking for ring gap or pistion to wall
Old Jan 28, 2004 | 03:56 PM
Cyber ITR's Avatar
Default Re: Engine rebuilders help !!!! piston clearance (GRTechnologies)
im not sure .....
what about if you tell me both ???
pistons clearance and ring clearance , its b18c1 pistons , 81.5mm
thanks man
Old Jan 29, 2004 | 02:16 AM
Cyber ITR's Avatar
up
help a brother out
Old Jan 29, 2004 | 07:58 AM
earl's Avatar
.005 will probably give you piston noise when it is cold. Call JE directly and ask a tech
Old Jan 29, 2004 | 08:12 AM
IntegracinGSR's Avatar
Let us know what JE told you just for other's future knowledge
Old Jan 29, 2004 | 08:15 AM
b18cx's Avatar
Default Re: (IntegracinGSR)
Not to jack the thread, but fixing to be in the same boat, Sleeved block, new pistons, ect........ Is there a way for someone Building there own motor to ckeck piston to wall clearence?
Modified by b18cx at 5:45 PM 1/29/2004
Old Jan 29, 2004 | 08:19 AM
lazerus's Avatar
Default Re: (b18cx)
i bet your engine builder normally puts togeather v8's
Old Jan 29, 2004 | 09:48 AM
Cyber ITR's Avatar
Default Re: (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">i bet your engine builder normally puts togeather v8's</TD></TR></TABLE>
how do you know ?!?!?!?!
Dc4LsTeG
Jul 6, 2012 11:16 PM
Datphan
Mar 12, 2008 08:58 AM
kenb16a
Feb 2, 2006 04:36 PM
95c1v1cs1
Jul 28, 2004 09:44 AM
quickergixxer
Oct 10, 2003 04:44 PM
