what for turbo 8:1, 8.5:1, 9:1, 9.5:1
hi all, looking to build block, for boost of 15-18psi on a t3/t4 turbo on a h23 motor.
i was personally thinking of 8.5:1 because its a daily driver and i want to keep low end torque
http://www.cardomain.com/id/boostlee
Re: what for turbo 8:1, 8.5:1, 9:1, 9.5:1 (boostlee)
9.0:1 is a nice happy medium for a turbo set-up.
I run 9.0:1 with 20psi sofar, this summer I plan on running roughly 25-28psi though with the same cr. Alot of guys are now starting to run 10.0:1 cr's since they yield a bit more power. Keep in mind it will slightly lessen your saferange when it comes to tuning and detonation.
9.5-10:1 C/R, don't forget that Honda's are efficient motors. Anything below 9.0:1 and you've just got a slug with a turbo.
Re: what for turbo 8:1, 8.5:1, 9:1, 9.5:1 (pissedoffsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol »</TD></TR><TR><TD CLASS="quote">if you want to keep torque/low end, don't even think about going below 9:1</TD></TR></TABLE>
Meh, I can fry the tires at 2300rpm's easily in second gear on a dry day. He has 3000 cc's more than me. You can make low compression motors like mine at 7.8:1 work well at low rpm's, especially with 2.3L.
escape2me
04-20-2004 12:49 PM
