Kit almost complete, whats wrong with the starter now?!
Old Jan 24, 2004 | 09:55 PM
RedStarGsr's Avatar
Default Kit almost complete, whats wrong with the starter now?!
hey guys, im very close, just purging the air through the send line but cant get the car to start heres what happens...
First off... charge battery all the way up and check terminals. try to start car and nothing. figure starter is dead. its old so i just bite the bullet and go buy a new one (couldnt hurt).
second. install the brand new starter, re-charge battery (just in case), check connections. turn the key and just click click click click as long as i hold the key. recheck the connections, take it out, and re-install. maybe the battery is dead right? just jumpstarting it from my moms pilot with jumper cables still nothing...i have no idea whats goin on or why it wont start.
please help, im very anxious and cant wait to get this thing running. any ideas? thanks
Old Jan 24, 2004 | 10:04 PM
TravSi's Avatar
Default Re: Kit almost complete, whats wrong with the starter now?! (RedStarGsr)
How old is the battery...it might not be able to hold a charge? i had that happen to me....I would double check your ground and power wires...maybe even check the fuses under the hood? Im sure you will find it will be something stupid, it always is when you complete a big project......Just double and triple check everything
civicshowracing65's Avatar
what does your kit include? maybe something you installed isn't right
Old Jan 24, 2004 | 10:12 PM
RedStarGsr's Avatar
nothing in the kit is electronic...the boost guage and injectors were installed when i was still n/a and car ran and started up fine then... so maybe just a new battery?
does the clicking sound like its getting power?
ive heard some rumors about flywheels not mating up or something...
Old Jan 24, 2004 | 11:55 PM
accordfreak's Avatar
Default Re: (RedStarGsr)
i have the same problem too.. changed the starter and everything...after a million clicks it starts.. it's getting quite annoying
anybody have any ideas?
btw: did you install a new flywheel? for the accord, clutchmaster had faulty flywheel rings gears causing the car to grind at start up or click..i dunno about integras though
Old Jan 25, 2004 | 12:26 AM
Kwuaymaikrup's Avatar
Default Re: (accordfreak)
Battery...I had the EXACT same problem. And get this, it was in my DA too.
-Ryan
Old Jan 25, 2004 | 07:32 AM
RedStarGsr's Avatar
so get a new battery and done? even though i charged that piece for eternity? i apprecaite your comments...
im running a 7.5lb fidanza flywheel as well...but its bee in for a whiel and never had a problem.
Old Jan 25, 2004 | 11:07 AM
I thought it was my starter as well. but after having them tested and my battery charged it still didn't work. As soon as I bought a new battery the problem was solved.
-Ryan
Old Jan 25, 2004 | 05:40 PM
RedStarGsr's Avatar
i charged both my batteries sitting around and still nothing... possibly could it be the starter terminals or something? i do have the battery in the trunk, maybe a bad connecton somewhere? but what boggles my mind is that it worked perfectly before i pulled it into the garage for the overhaul...hmm...weird. i guess ill just go bite the bullet (again) and get a new battery too...
Old Jan 25, 2004 | 05:54 PM
tSuperbike69's Avatar
Sounds like you have a ground off check them all and make sure they are clean and tight
Old Jan 26, 2004 | 06:19 PM
Default Re: (tSuperbike69)
sheezzz this weekend i finally fixed my problem. bad installation of the alarm = loose starter wire.. plus i sanded down the ground connection for a clean surface and tightened the connections on the battery.. started my car 10 times in a row no problems now.. so i'm guessing now it's only your electrical that's causing that problem nothing mechanical. go over your battery to under your dash with aftermarket alarms etc etc
Old Jan 26, 2004 | 06:25 PM
rondigs's Avatar
My bet is on the battery. Especially if you stored the battery on the ground while you were doing the buildup. Buy a battery. If it doesn't solve the problem (which I doubt), you can always take it back...
lilsol89
Jan 5, 2009 03:57 PM
94AcuraIntegraGsr
Apr 8, 2006 02:25 PM
lazykiwi
Nov 27, 2004 04:17 PM
mattL
Jun 25, 2002 07:33 PM
