TurboXS Dual Stage Boost Controller Install Help Again...
Old Jan 24, 2004 | 10:01 PM
civicshowracing65's Avatar
Default TurboXS Dual Stage Boost Controller Install Help Again...
i needed some help on part of my install. the instructions say "Mount the Dual Stage Boost Controller to the vhicle cassis in a location such that it can be reached by a flexible pressure hose running from the positive side of the turbo when disconnected from the wastegate actuator. Use two(2) of the M4 nut and screws." The thing is, on my civic, I couldn't find any place on the chassis to mount the controller. Instead I strap tied it onto ac line(i think it was ac). Is it ok to be strap tied or does the controller need to be mounted on the chassis? I already have the wires grounded, so it shouldn't matter if it was on a chassis or not..right? Need help asap. thanks
here's what it looks like
http://www.geocities.com/sweet....html
Old Jan 24, 2004 | 10:04 PM
5thgencivic's Avatar
Default Re: TurboXS Dual Stage Boost Controller Install Help Again... (civicshowracing65)
It's fine strapped.
Old Jan 24, 2004 | 10:11 PM
Default Re: TurboXS Dual Stage Boost Controller Install Help Again... (5thgencivic)
thank you...i can go do it now and still make it down to the track 10 psi here i come!
slotec
Apr 9, 2008 06:56 AM
FredoSP
Jun 1, 2004 09:54 PM
speeds
Mar 17, 2003 03:51 PM
poison
Apr 14, 2002 10:44 AM
