need HELP taking hks ss bov off welded pipe????
sup guys, i need help taking my hks ss bov off a welded pipe.. i just got it and need to get a flange for it to bolt down onto my own pipe. i heard that i'm gonna need some sort of a c clamp or something.. if any of you guys can help me out hit me ups.. i'm in fremont/bay area!
Re: (T-RO)
hacksaw? you mean just saw it off around the round bottom of the bov? hrmm any other suggestions? i noticed there's 2 holes on the left side of the round part where its welded.. is there a key to open it?
Re: (alfee)
are you just trying to take the bov of the flange. You will need a 90 degree c-clip pliar. spread them apart and then pull it should come right off
Re: (alfee)
I use the snap on unit it. you can get one from sears however
let me post a pic right quick they csot abotu 12.99 and up make sure you get oen that is 90 degree it makes life easier
Re: (alfee)
my friends and I used those pliars that go out and slant down. It was a biatch trying to my hks blow off valve in . Probably been faster if i had the real tool
Re: (redturbocivic)
yep, well i went to kragen and bought a cheap o ring snapper tool w/ the 90 degree hooks and it was a bitch to take off.. actually it didn't even come off.. kinda messed up the tool too. so i returned the cheap *** tool.. maybe will stop by sears and get a craftsmen set. just still hopeful right now i guess...
Re: (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus »</TD></TR><TR><TD CLASS="quote">try taking it off with two screwdrivers if you think its hard (its really hard that way!)</TD></TR></TABLE>
no joke thats the days before known knew how to do anything.
Re: (b18bturbo)
ok guys, heres the deal. my bov pipe used a bolt on pattern which i had a greddy type r bov bolted on it... now i got a hks ss bov... does anyone know where i can get the bolt on settup instead of the metal/aluminum flange to weld it? hit me ups!
Re: (alfee)
i thought there was some sort of a flange where you clip the bov onto, then bolt that onto the pipe which is already setup for bolt on? maybe i'm wrong...
Re: (b18bturbo)
hrmm $20 shipped for the aluminum flange, sounds good. ok since my car is in the shop, i will notify them to see how much they can get a flange for, if it's more than 20 bucks then i'll buy it from you... i'll get back to you on here.. thanks!
Re: (RotiEatter)
http://cgi.ebay.com/ebaymotors...39730
hey i saw this bov adapter on ebay.. will i be able to use my hks ss bov on it? since my ic pipe is made for the bolt on?
Re: (alfee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfee »</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...39730
hey i saw this bov adapter on ebay.. will i be able to use my hks ss bov on it? since my ic pipe is made for the bolt on? </TD></TR></TABLE>
i wanna know the same thing. can u weld a hks flange onto that thingy? and bolt it to the greddy?
Re: (egturbo)
for reals man! seems like peepl keep telling me to just get an aluminum flange and weld it onto my pipe, but by doing that i'd have to cut my existing bolt on flange thats on the pipe off. that'd suk!!! hrmm any ideas fellas?
