Boost on a semi stock block
Old Jan 26, 2004 | 07:52 AM
Griffin@Camtech's Avatar
Default Boost on a semi stock block
How much boost is "safe" on this block
B18B w/GSR head. actual compression ratio of 9.1. bored .20" over with eagle rods, and JE pistons. with a block gaurd fit by machine shop.
its a t3/t4 drag turbo system tuned with hondata w/boost option.
Thanks
ek2nr
Old Jan 26, 2004 | 07:59 AM
RedTegLS's Avatar
Default Re: Boost on a semi stock block (EK2NR)
12psi with proper tuning is about max
Old Jan 26, 2004 | 08:28 AM
TurboJesse
Guest
Posts: n/a
Default Re: Boost on a semi stock block (RedTegLS)
500+ whp with good tuning...
Old Jan 26, 2004 | 10:11 AM
Default Re: Boost on a semi stock block (Mpir3)
top
Old Jan 26, 2004 | 10:21 AM
TurboJesse
Guest
Posts: n/a
this question is asking 10 times everyday, do a ******* search
Old Jan 26, 2004 | 12:29 PM
Irishweird00's Avatar
Banned
yup.... I asked it before
Old Jan 26, 2004 | 12:44 PM
MikeMAN's Avatar
there is NO set number, 12psi on a small *** turbo is easy....12psi on a holset turbo used in a mac truck is a little different.....the main question is more like how much POWER can a stock block handle....
mike
Old Jan 26, 2004 | 01:35 PM
B18bEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">12psi with proper tuning is about max </TD></TR></TABLE>
thats a retarded answer. you should be able to make 400 with no problem. you might think about getting a diff. turbo though
Old Jan 26, 2004 | 02:48 PM
Cramerox's Avatar
Default Re: Boost on a semi stock block (B18bEK)
Tunning
Old Jan 27, 2004 | 11:38 AM
MikeMAN's Avatar
Default Re: Boost on a semi stock block (Cramerox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox &raquo;</TD></TR><TR><TD CLASS="quote">Tunning</TD></TR></TABLE>
exactly..if its in the hands of ME...expect that **** to be blown at 5psi on a t25...however, st00pid and the other great tuners on this board do great things
mike
Old Jan 27, 2004 | 12:30 PM
_jester_'s Avatar
This is the kinda **** that causes people to **** up there engines.
Old Jan 27, 2004 | 12:32 PM
Atheist's Avatar
Default Re: Boost on a semi stock block (XratedSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XratedSi &raquo;</TD></TR><TR><TD CLASS="quote">
This is the kinda **** that causes people to **** up there engines. </TD></TR></TABLE>
Oh really? So, if he ran stock boost on a DSM t25, it'd be ruined?
Old Jan 27, 2004 | 01:25 PM
MikeMAN's Avatar
Default Re: Boost on a semi stock block (Atheist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist &raquo;</TD></TR><TR><TD CLASS="quote">
Oh really? So, if he ran stock boost on a DSM t25, it'd be ruined?</TD></TR></TABLE>
lol
Old Jan 27, 2004 | 01:36 PM
BoostedITR41's Avatar
Default Re: Boost on a semi stock block (MikeMAN)
you can make good power on stock sleeves. on totally stock internals on my ITR block with inline pro head gasket and block gaurd I have run 14psi daily for 4 monthes no problems yet
Old Jan 27, 2004 | 02:51 PM
Kataku2K3's Avatar
Default Re: Boost on a semi stock block (BoostedITR41)
That's pretty much Lane's exact setup except he's working with a stock sleeved B18C, 9.5:1 JE slugs, Eagle rods, Portflow head, Hondata, T3/T04E, etc. He only runs pump gas, makes 375whp (which isn't too bad for 12lbs.) and runs consistent 11.50's in his full interior EJ6... You have a really nice street setup to work with I would say 12-14lbs. max but that's just me and stock sleeved motors, yes people have done more but we'll only do it unless the block is sleeved... Just my $0.02
EDIT: I'd skip the blockgaurd tho, I hate those things and you're motor will hold up just fine without it...
Dugdude
Aug 25, 2013 11:43 PM
B16afmaxt
Nov 11, 2009 04:27 PM
civicb18Tkid
11
Apr 26, 2007 07:22 PM
moesrex
May 6, 2006 06:31 AM
aut0tek
Apr 2, 2003 02:50 AM
