Oil leak from the Feed line and the Oil Temp harness of a 93 prelude, Help!
From the feed line with the Oil temp harness on the back of the block is leaking oil. I'm not too sure if me and a partner fastened enough or not. Help, on how to stop the leak. We tried using hondabond but are not sure if we use enough too. help please. I'm loosing a lot of motor oil everytime the car is park.
Re: Oil leak from the Feed line and the Oil Temp harness of a 93 prelude, Help! (btrim23)
You do not want to use honda-bond on the oil line fittings. As mentioned before use teflon or a teflon paste on all the non-45 degree male end fittings.
Basically you are going to have to remove all of the lines, clean them with brake parts cleaner, add the teflon, then tighten them back down. That should fix your problem.
