Direct port install question
Old Jan 25, 2004 | 06:17 PM
quik1's Avatar
Default Direct port install question
I'm in the process of thinking out my nitrous kit and had a question about fuel supply. Would there be a problem with taking off the end cap of a stock fuel rail, building it up with some weld then tapping into it. I didn't think that there would be a problem but I may have over looked something. Any input would be great.TIA.
Old Jan 25, 2004 | 06:34 PM
baphomet's Avatar
Default Re: Direct port install question (quik1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">I'm in the process of thinking out my nitrous kit and had a question about fuel supply. Would there be a problem with taking off the end cap of a stock fuel rail, building it up with some weld then tapping into it. I didn't think that there would be a problem but I may have over looked something. Any input would be great.TIA.
hmm
You could do it like that, what I would do is use the second port on a fpr (like the aeromotive one - i forget the part number) if you were getting one anyway.
Or cut the line between the rail and fuel filter, but I would do what you suggested rather than cut the line. Any would work though.
Old Jan 25, 2004 | 06:55 PM
quik1's Avatar
Default Re: Direct port install question (slashDEVslashNULL)
Good idea about the FPR but I already have a B&M one and I don't want to buy a new one, I also don't want to tee into the line. I'm just wondering if it would cause any cylinders to go lean if I did it the way I suggested.
Old Jan 25, 2004 | 07:05 PM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">Good idea about the FPR but I already have a B&M one and I don't want to buy a new one, I also don't want to tee into the line. I'm just wondering if it would cause any cylinders to go lean if I did it the way I suggested.</TD></TR></TABLE>
I don't think so - as long as your fuel pressure stays the same you should be okay.
Before you spray, disconnect the vac line from your fpr and manually activate the fuel solenoid (point the fuel line in to a bucket or something) and watch your fuel pressure gauge - adjust accordingly. (this is to see the flowing fuel pressure, though you prob. don't need to do it....I am getting sleepy )
Old Jan 26, 2004 | 07:34 AM
quik1's Avatar
Thanks for the advice I think I'll be doing it that way I also have a holly 255lph fuel pump so I think I'll be all right.
Old Jan 26, 2004 | 04:54 PM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the advice I think I'll be doing it that way I also have a holly 255lph fuel pump so I think I'll be all right.</TD></TR></TABLE>
Take a pic of the finished product and post it.
91whiteZCrex
Apr 30, 2006 04:37 PM
Ahknodd
Honda Civic (2001 - 2005)
10
Apr 24, 2006 08:29 AM
StockBlockRob
Dec 1, 2004 02:35 PM
Shakes
Jan 31, 2004 12:41 PM
integraLS
Apr 25, 2002 06:20 PM
