Which basic fuel management setup for LS turbo?
Old Jan 27, 2004 | 09:49 AM
Bictorious's Avatar
Default Which basic fuel management setup for LS turbo?
Hey im kinda low on cash and was wondering what kinda of cheap fuel management is good for only 10 psi of boost on my LS turbo. What things should i get like : fmu? Injectors? fuel pump? Safc? whats the best combo for that low of boost?
Old Jan 27, 2004 | 09:57 AM
b18bturbo's Avatar
Default Re: Which basic fuel management setup for LS turbo? (Bictorious)
10psi yuo can probably run the AFC hack with dsm 440cc
Or the other cheap alternative
is use the fmu with high pressure pump
Old Jan 27, 2004 | 10:06 AM
COOKIEPUSS's Avatar
Hondata S100b
vafc hack
uberdata
Old Jan 27, 2004 | 10:22 AM
Bictorious's Avatar
how much do hondatas and uberdatas cost? whats afc hack?
Old Jan 27, 2004 | 10:33 AM
Kataku2K3's Avatar
Hondata S200, simple and works great... Tho I really don't know prices we normally charge ~$950 for Hondata install and dyno tuning but really the Hondata shouldn't be much more than ~$500... I'm probably off by a little but just to give you a ballpark figure... Good Luck
Old Jan 27, 2004 | 11:02 AM
RedTegLS's Avatar
Default Re: Which basic fuel management setup for LS turbo? (Kataku2K3)
Whatever you do dont forget your Walbro 255lph intank fuel pump! No sence in upgrading everything else if you dont have anything pumping it from the start. They are $99 shipped
Old Jan 27, 2004 | 11:14 AM
Kataku2K3's Avatar
Default Re: Which basic fuel management setup for LS turbo? (RedTegLS)
Injector wise we normally run 370-440's for 6 to 9lbs., 720-900's on 12 to 20lbs., and 1000's+ at around 22lbs. and higher...
Old Jan 27, 2004 | 11:23 AM
Burke's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">Whatever you do dont forget your Walbro 255lph intank fuel pump! No sence in upgrading everything else if you dont have anything pumping it from the start. They are $99 shipped </TD></TR></TABLE>
http://www.autoperformanceengineering.com - should only be like 85 -90!
Old Jan 27, 2004 | 12:18 PM
DA-MAX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bictorious &raquo;</TD></TR><TR><TD CLASS="quote">how much do hondatas and uberdatas cost? whats afc hack?</TD></TR></TABLE>
uberdata = program is free(+$100 for a burner)...its a great program, but if you aren't DIY or willing to learn a few things than it might not be for you, awesome program though --&gt;
http://www.ecimulti.org/uberdata/forum/index.php
turbo89civicb18hatch
Mar 29, 2004 08:22 AM
Bictorious
Mar 9, 2004 09:14 AM
Bictorious
Feb 16, 2004 09:36 AM
BoostedSi
Feb 23, 2002 09:38 PM
Cyrio
Feb 4, 2002 05:22 PM
