Multec 2 injectors
Old Jan 28, 2004 | 08:13 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Multec 2 injectors
Has anyone heard about these injectors? I get a lot of calls for them. They are made by delphi and alot of the OEM Auto manufactors use these apparently. I dound a PDF on their website. Check it out and give any info you guys might have: http://www.delphi.com/pdf/e/multec2_inj.pdf
[pirate]arrrrrrrrrrrrrrrrt[/pirate]
Old Jan 28, 2004 | 08:18 AM
b18bturbo's Avatar
Default Re: Multec 2 injectors (Arturbo)
What do you want to know abotu them Art.
Old Jan 28, 2004 | 08:23 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Multec 2 injectors (b18bturbo)
Sizes, fits honda rail?
Old Jan 28, 2004 | 08:31 AM
b18bturbo's Avatar
Multec was created by Rochestor Products when they were contracted out by GM to do there injector duties in the late 85s time frame. Prior to 1985 GM was utilizing a bosch pintle style injector in there 85 fuel injector camaro and Corvette. That engine L98 was designed to use the bosch pintle. Fed up with clogging of the pintle in 85-86 there is TSB if you look at the Alldata website aboout that just fyi.
Pintle injectors suck becuz they get clogged easily
The Rocehstor Ball and Seat mutlec 2 design injectors are far supeior. They do not fit honda rails but however can be machined to fit
Part numbers are below
STATIC FLOW RATE (lb/hr) STATIC FLOW RATE (gr/sec) DYNAMIC FLOW RATE (gr/sec)* OE NUMBER DELPHI SVC RESISTANCE (ohms) DRIVER TEST PRESSURE (kPa) SPRAY CONE ANGLE (deg)** TIP LEAK
18 2.44 0.487 17120683 12.00 SATURATED 300
24 3.061 0.597 17122683 12.00 SATURATED 300
30 3.8 0.666 25324366 17113812 12.00 SATURATED 300 14.2 2.2 MAX
42 5.3 0.945 25324743 17113813 12.00 SATURATED 300 21.9 2.2 MAX
50 6.4 1.100 17104487 17113738 12.00 SATURATED 300 22.4 2.2 MAX
55 6.9 1.340 25324744 17113741 2.00 PEAK AND HOLD 300 20.3 2.2 MAX
65 8.2 1.530 25324367 17113814 2.00 PEAK AND HOLD 300 24.4 2.2 MAX
75 9.5 1.750 17104988 17113742 2.00 PEAK AND HOLD 300 22.5 2.2 MAX
85 10.7 1.990 25324746 17113743 2.00 PEAK AND HOLD 300 16.6 2.2 MAX
95 12 2.200 17104959 17113744 2.00 PEAK AND HOLD 300 17.6 2.2 MAX
Old Jan 28, 2004 | 08:40 AM
Marauder's Avatar
They are being used a lot in domestic hot rod EFI applications. Just need to convert to the different connector style and drill out the fuel rail and space it higher. Or go the easy route and buy the Edelbrock fuel rail meant for domestic fuel injectors, if they have one for your application.
uvamosk
Sep 11, 2011 06:05 AM
JDM-JAMES
Feb 18, 2009 06:57 PM
K i l l a B e e.
Dec 19, 2008 02:28 PM
balmo
Dec 21, 2007 09:28 AM
