d16 greddy turbo help needed
Im buying a greddy kit with bov and ic but thats it. It needs a fmu and some sort of managment. What do you guys recommend? I would like to run higher boost very soon like 8 lbs or so. Thanx for any help.
Re: d16 greddy turbo help needed (johnsona)
How much is the hondadata?
How much is the afc hack, what is it and where do you get it?
Also will I still need the fmu?
Thanx again
Thanx again
Re: d16 greddy turbo help needed (kholmes)
Uberdata if you don't mind a little hands-on and learning. It's cheaper than the AFC hack, and gives much better results, as any true standalone does.
Re: d16 greddy turbo help needed (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">Uberdata if you don't mind a little hands-on and learning. It's cheaper than the AFC hack, and gives much better results, as any true standalone does.</TD></TR></TABLE>
I agree, got brains? True this, if not go another direction or find a friend.
You really need a wideband to get the best results. If your cheap, like me, but dont have a wideband. I would recommend contacting someone on this board to tune your **** with uberdata. I'd put uberdata right beside hondata, its just a little more difficult since not many shops tune it.
Nick
Nick
the vafc hack you need a vafc 450cc injectors but get rc440 because you wont need a resistor box on if you get 450cc you will need it walbro 255 fuel pump and set the vafc and boost to 10lbs you go no problems . forget the fmu
Yeah, I just found a site about this but I didnt know about the resisiter box. Where do you get the 440's and do i get the newer afc? Also does the afc control boost?
