Parts List...Recommended places to buy from?
To make a long story short I've been researching where to get parts to turbocharge my car. I think I've just about got everything down. Now I'd like to know if any of you know where I can find any of this stuff for cheaper than I've already found. Here's what I'm still looking to buy, with the prices from the places that I've found the parts:
TiAL 40mm Wastegate - $330 from importparts.com
3" High Flow Cat - $95 from importparts.com
3" Flex Pipe - [waiting on price from importparts.com]
Thermal R&D 3" Cat Back - $525 from importparts.com
Pusher Fan - $75 from AutoZone
Spearco Intercooler - around $350 from eBay
Misc. Mandrel Bent Pipe for Charge Pipe and Down Pipe - $125 from jcwhitney.com
Oil feed & Return Lines - $125 from Flamenco-T here on HT
Silicone Connectors - Around $100 from turbocharged.com
Stainless Steel T-Bolt Clamps - Around $100 from turbocharged.com
I've already got the turbo, 550cc injectors, ECU, BOV, and I'm getting Hondata through Mahdavi.
The things I really would like to find for less are:
SS T-Bolt Clamps
Silicone Connectors
If you know where I can get these or any of the other parts for less, help a brother out.
SS T-Bolt Clamps
Silicone Connectors
Re: Parts List...Recommended places to buy from? (DaX)
atpturbo.com, http://www.roadraceengineering...s.htm
Re: Parts List...Recommended places to buy from? (sporkcrx)
http://www.dnaparts.com/hoses.htm
INTAKE Hoses (will be just as good as those high price couplers out there)
You have to call to order but most will be about $7.50-$12 depending on what you order. Very friendly and helpful on the phone too!
http://www.partssystems.com/sh...REEZE
Breeze SS T-bolts...very strong and very affordable!
#TB250 will fit over most couplers on a 2.5" OD pipe, make sure you realize that 2.5" is the MAX ID" of the T-bolt, I screwed up in that respect the 1st time I ordered.
Thanks again guys. I'm going to buy my T-Bolt Clamps from http://www.partssystems.com/sh...REEZE and I'm going to buy a 2' length of silicone hose from http://www.roadraceengineering...s.htm ...these places seemed to have the best prices.
Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">http://www.partssystems.com/sh...REEZE[/url] </TD></TR></TABLE>
they have the cheapest T bolt clamps of im not mistaken
You could also try http://www.vecco.net T bolt clamps are $3.79 there
for cheap precut silicone try http://www.atpturbo.com $6 for straights, and $17.50 for reducers, atp had the best prices on pre cut couplers.
Alos on the pusher fan i thouhg the autozone fans were only like $65, but for $75 you may look on ebay, they usulaly have Spal fans for around $75
Re: Parts List...Recommended places to buy from? (tgh99si)
Well almost everything has been purchased for my DIY kit. Below is a list of what I have bought and a list of what I need, both lists with costs. All prices include shipping.
WHAT I HAVE BOUGHT SO FAR
Lovefab Sidewinder Manifold [not recieved yet] - lovefab.com - $850
Thermal R&D 3" Stainless Cat Back Exhaust - importparts.com - $600
Turbonetics T3/T04E 60 trim w/ stage 3 wheel - hondaclassifieds.com - $460
TiAL 40mm Wastegate [0.4 bar spring] - importparts.com - $330
20"x8"x2" FMIC [2.5" inlets] - 92HB_HB - $240
TiAL Blow Off Valve - extremepsi.com - $209
RC Engineering 550cc Peak & Hold Injectors - ebay.com - $200
Charge pipe materials [I bought too much ] - jcwhitney.com - $132
Oil Feed & Return Lines - fast-turbo.com - $125
Carsound 3" Hi-Flow Catalytic Converter - importparts.com - $99
12" Slim Pusher Radiator Fan - 92HB_HB - $50
2' Length of 2.5" Silicone Hose - roadraceengineering.com - $50
Downpipe Materials - jcwhitney.com & jegs.com - $65
3" Flex Pipe - b18bturbo - $40
T3 Exhaust Flange - atpturbo.com - $35
P28 ECU - local seller - $30
T-Bolt Clamps - partssystems.com - $33
Silicone 2" to 2.5" Hose Connector - roadraceengineering.com - $23
Honda OEM Resistor Box - ebay.com - $15
Two o2 bungs - atpturbo.com - $10
o2 bung block off bolt - atpturbo.com - $5
TOTAL SPENT - $3,601
WHAT I HAVE YET TO BUY
T3 Gasket - atpturbo.com - $8
ECU Socketing - hondata.com - $65
ATP Manual Boost Controller - atpturbo.com - $69
Greddy Turbo Timer - evasivemotorsports.com - $85
Hondata S200B - hondata.com - $495
Hondata Installation & Tuning - balanced performance - $365
TOTAL TO SPEND - $1,087
TOTAL FOR EVERYTHING - $4,688
Now who said boosting was cheap????
Modified by DaX at 9:55 PM 2/15/2004
mcmaster carr= 2.5" Nitrile Coolant tubing. It comes in 3' for a $27+shipping. Holds like 29psi or something and 200-300 degrees. Basically it will work no problem.
ATP MBC, ah ive heard too many great things about dawes devices, im buying one of those for like $30 or something.
Hondata......that alone is costing you $925(my mental math is probably off).
Now im looking at your setup, and im seeing this is your basic 300whp or less kit. why buy hondata when uberdata is free? Buy a plx devices WB, a chip burner. thats $400. chip your ECU yourself=$30, if you are afraid to, there are guys here and at pgmfi that do it for under $60. Basically you can do the whole fuel management WITH A WIDEBAND! for less than $500.
The reason i suggest the plx devices WB. Basically its small, fast as hell, has narrowband simulation which will basically allow your ECU to record WB values for the datalogging that will sooner or later be incorperated with uberdata.
If you are obd0, you are even better off. http://www.turboedit.org They already have datalogging and on the fly tuning is about a half a step away or full release, not sure at this point. basically, hondata is eating $1000 of your hard earned dollars. You said you wanted your kit to be DIY, well lets keep it DIY all the way. Uberdata or Turboedit
