Boost Controller Poll!!
Old Jan 25, 2004 | 06:22 PM
streetlvlhatch's Avatar
Default Boost Controller Poll!!
I am having a tough time deciding which boost contoller to buy. I have heard so many pros and cons for each and am stuck. Could you also let me know why one is better or not. Thanks.
Also, if anyone would like to sell me one that would be great!!!!
Modified by streetlvlhatch at 11:50 PM 1/25/2004
Old Jan 25, 2004 | 07:29 PM
vaporboy12's Avatar
i like my hks evc 5
Old Jan 25, 2004 | 07:32 PM
alpha's Avatar
Default Re: Boost Controller Poll!! (streetlvlhatch)
I went with the Blitz SBC i-D. Too tired to type any more. Good night.
Old Jan 25, 2004 | 08:00 PM
ProEater's Avatar
Default Re: Boost Controller Poll!! (0x64)
greddy profec b is good enough for me.....
(rhyme master)
Old Jan 25, 2004 | 08:05 PM
B18bEK's Avatar
had the profec B but it sucked so i moved on the the Turbo XS manual boost controller working great so far
Old Jan 25, 2004 | 08:26 PM
Ek00fbp's Avatar
Default Re: (B18bEK)
Blitz spec R is good, real good.
Old Jan 25, 2004 | 08:49 PM
BoostedITR41's Avatar
Default Re: (Ek00fbp)
original profec B
Old Jan 25, 2004 | 09:27 PM
NuclearB18B's Avatar
i wish i could afford a electronic boost controller. i'll have to settle for my turbo xs hp mbc. working fine so far...
Old Jan 25, 2004 | 10:19 PM
Joseph Davis's Avatar
Default Re: Boost Controller Poll!! (ha illuminato un)
Disconnect your wastegate signal and modulate boost by feather the throttle, like a real man!
(yes, sarcasm)
Old Jan 26, 2004 | 01:53 AM
calib17a's Avatar
I went with the HKS EVC II because it uses an intelligent stepping motor. A CPU is imbedded into the stepping motor. This creates more direct and accurate control as the CPU virtually eliminates lag time between the stepping motor and control module. Thereby increasing linear boost control and stability. It's a closed loop stepping motor, you are insured the same most accurate and stable boost levels possible. Boost pressure will rise faster and earlier in each gear and be maintained without fear of overboosting. Also the EVC EZ II is capable of being upgrade to a full EVC unit by simply adding an EVC Display unit.
Old Jan 26, 2004 | 07:00 AM
Default Re: Boost Controller Poll!! (calib17a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calib17a &raquo;</TD></TR><TR><TD CLASS="quote">I went with the HKS EVC II because it uses an intelligent stepping motor. A CPU is imbedded into the stepping motor. This creates more direct and accurate control as the CPU virtually eliminates lag time between the stepping motor and control module. </TD></TR></TABLE>
Yeah, the lag time it takes to traverse 3 feet of wire from the CPU in the boost controller, of equivalent electronic boost controllers, at something just short of the speed of light creates a horrible lag problem.
You can go deeper into how HKS has their PWM routines set up to make it so special, since you haven't really explained anything so far. A code dump of said microcontroller would be most enlightening and porve your point completely
Old Jan 26, 2004 | 08:42 AM
TravSi's Avatar
Default Re: Boost Controller Poll!! (J. Davis)
Joe P.
Old Jan 26, 2004 | 08:48 AM
@irborne's Avatar
TurboSmart's e-Boost Controller;
Old Jan 26, 2004 | 11:16 AM
Nextelbuddy's Avatar
Default Re: Boost Controller Poll!! (@irborne)
i had the same diliemna i went with the greddy profec b spec II conrtroller and i love it.
you can control spool up time, how fast it spools up and when it spools up. and i only paid 295 shipped for mine on ebay.
Old Jan 26, 2004 | 11:17 AM
RyanAutry's Avatar
This is probably one of the best boost controllers on the market today.
http://www.overboost.com/obs/product.asp?pid=19856
Old Jan 26, 2004 | 11:26 AM
Johnyquest's Avatar
Default Re: Boost Controller Poll!! (RyanAutry)
I'll make you a ball and spring manual boost controller for $20 shipped, money back if you don't like it. Don't spend money on somthing so expensive!
Old Jan 26, 2004 | 11:34 AM
Default Re: Boost Controller Poll!! (Johnyquest)
Do any off these controllers have a boost cut in case of spikage?
Old Jan 26, 2004 | 12:35 PM
SiBirdie's Avatar
nothing but the best... Blitz SBC
Old Jan 26, 2004 | 12:57 PM
slvrstns2000's Avatar
no love for the innovative boost controller??
Old Jan 26, 2004 | 01:11 PM
Default Re: (99crx01)
little pricy for the innovative. I cant afford that much bling!
Old Jan 26, 2004 | 01:27 PM
poid's Avatar
Blitz SBC-iD, very sexy
Old Jan 26, 2004 | 02:48 PM
len's Avatar
len
AEM EMS
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetlvlhatch &raquo;</TD></TR><TR><TD CLASS="quote">Do any off these controllers have a boost cut in case of spikage?</TD></TR></TABLE>
The Blitz SBC i-D does.
Old Jan 26, 2004 | 02:50 PM
alpha's Avatar
Default Re: (poid)
Old Jan 26, 2004 | 03:01 PM
94cxHybrid's Avatar
New User
Default Re: (0x64)
i love my avcr. I found it difficult to use at first, but now i have the hang of it.
