before tuning ?s
Old Feb 16, 2004 | 02:49 PM
b16hybridsol's Avatar
Default before tuning ?s
i'm about 2-3 weeks away from gettin my car tuned at dpr in toledo, they've just got a mustang dyno and i had a few questions on my set up before i get it tuned, to see if there is anything that you guys think i should change, within a reasonable amount of money like no more than 500
this is all in a 94 teg
-stock jdm h22a w/ lsd
-clutchmasters stage 3 clutch
-fidanza 8.5lb. flywheel
-dsm 450 blue tops
-manual boost controller (planin 8psi)
-fmax manifold
-deltagate with 7psi spring (running open waste gate)
-t3/60-1 turbonetics turbo
-revhard down pipe(came hacked only got top half so right after the turbo it bends then is 3 inch back to the cat which is 2 1/2 inlet and outlet to an n1 cat backalso 2 1/2)
-sperco front mount ic
-custom ic piping with hks ssqv
-all silicon lines from im
-iridium plugs
-hondata stage 4b with all the works (p30 ecu)
-stock prelude vtec fuel pump
-a couple little things that i think will affect the tuning, i kept the p/s, the dyno like i said is a mustang dyno so i expect to have some lower numbers, but how much lower should they be as compaired to everyone elses dyno jet numbers, i also went with 16s with 45 walls instead of 15s, i don't think that will affect much but tryin to get you guys all available info
-i think thats about it. Anything you guys think i should do or add or change before tunning, or any recomindations about tuning it, thanks
Old Feb 16, 2004 | 02:54 PM
TurboJesse
Guest
Posts: n/a
Default Re: before tuning ?s (b16hybridsol)
get rid of the deltagate for a tial..
Old Feb 16, 2004 | 03:03 PM
DaX's Avatar
DaX
Loved
Community Favorite
I would run Stock NGK plugs with the Hondata unit if it were me. I would also consider what Mpir3 said about the wastegate.
Old Feb 16, 2004 | 03:14 PM
the deltagate is a mark 2 so its not as bad as the originals, previous owner said he had no problems with it
Old Feb 16, 2004 | 06:43 PM
bump any more ideas?
Old Feb 17, 2004 | 04:21 AM
bump
Old Feb 18, 2004 | 03:22 AM
come on people be honest i know my set up isn't that good
Old Feb 18, 2004 | 06:45 AM
RedTegLS's Avatar
Your spending a lot of money why the $50 injectors? Get some RC550's Also, that flywheel is a little light. I think general opinion is that a 12lb is perfect for boosted cars.
hondab16iceland
Jul 3, 2015 07:58 AM
ScrapinSi
Aug 2, 2004 08:43 PM
Ty.
Apr 2, 2004 08:11 PM
gelok
Nov 10, 2003 08:48 PM
