Help Overboosted!!!
Old Feb 18, 2004 | 04:07 AM
Matt B's Avatar
Default Help Overboosted!!!
Um so forgetting that my car doesn't have a working wastegate, i floored it and overboosted to around 17psi. As soon as it happened I was like "oh ****". I was only a mile from work when it happened so all i know now is that there is a loud ticking noise comming from my engine bay. My engine sounds the same as far as i can tell but with a loud ticking noise comming from the left of the engine. It is rpm dependent and it sounds like a click every second at idle. My question is what could it be? A bent rod? Cracked sleeve? fucked valve? Cracked ringland?
The car still makes boost because the bov was working after the incident. I didn't smell any burning **** either. ****, I am stupid.
This is on a D16y8 with the greddy kit.
Old Feb 18, 2004 | 05:19 AM
RedTegLS's Avatar
Default Re: Help Overboosted!!! (Matt B)
A ticking that is rpm dependant sounds like a bent valve. It is definately not a knocking? Just ticking?
Old Feb 18, 2004 | 06:33 AM
Matt B's Avatar
Default Re: Help Overboosted!!! (RedTegLS)
i don't know what rod knock sounds like, but its not like a vibration its just a click sound added to the normal engine noise.
Old Feb 18, 2004 | 08:48 AM
TeamCracka's Avatar
I've got the same **** ... actually since I bought my motor.
I'd put money on a bent valve, but I'm not positive and will be taking out and rebuilding my motor hopefully starting this weekend to see what's really up.
When you hit that boost, did you immediatly redline the motor? I did once because the clutch slipped 100% and it just shot up to like 9000 RPMs
Old Feb 18, 2004 | 09:14 AM
Matt B's Avatar
Default Re: Help Overboosted!!! (TeamCracka)
yeah the clutch slipped and it went to redline. Boost owned me.
Old Feb 18, 2004 | 09:36 AM
psileepR's Avatar
New User
how much vacuum does your boost gauge read at idle? id do a compression or leakdown test to make sure.
im voting for a bent valve too... gl
Old Feb 18, 2004 | 09:41 AM
TeamCracka's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt B &raquo;</TD></TR><TR><TD CLASS="quote">yeah the clutch slipped and it went to redline. Boost owned me. </TD></TR></TABLE>
Yep, overreving will bend valves, Im put my money on that. Sucks man.
have you done a compression test?
Dlauth
Jan 12, 2011 08:20 PM
jhammond_82
Oct 16, 2009 10:53 AM
v8killaz
May 13, 2009 09:41 PM
wade
Mar 18, 2009 01:30 AM
pimpinainteasy
Aug 4, 2003 02:51 PM
