How tough to get 13s out of an sohc turbo in a crx?
Want to use a small turbo for very fast spool for just some street use some small races. Nothing tracked or anything like that just want it as a quick beater for daily driving. Thought about maybe a Vw Turbo or a Saab t3 they seem to spool up real fast.
Re: How tough to get 13s out of an sohc turbo in a crx? (Spooled1.6L)
A CRX shouldn't be toooo hard to get into the tweleves, with slicks that is. It's so light.
Try a drag kit or revhard kit, it's simple comes with what you need. And it'll put you where you want to be, take what you don't need out of it, and slap some slicks on it and you would be pretty quick.
New User
if you can afford it get the greddy kit for your car. well put together kit.
there have been members that hit 12's in the 1/4 mile with it in a hatch.
13's will be easy on street tires even provided you dont COMPLETELY suck at driving hahah
good luck
mike
good luck
mike
Re: How tough to get 13s out of an sohc turbo in a crx? (MikeMAN)
Sounds good. How much boost are those kits running? And this is on the stock Crx Si block. I might even throw some lower compression pistons in so I can up the boost and make the thing a little monster for daily driving
HT Username
09-30-2004 08:24 AM
turbob18a1
06-07-2003 09:23 PM
