missing link on a 91 teg 0bd0???please help
Old Feb 18, 2004 | 07:54 PM
91tegrals's Avatar
Default missing link on a 91 teg 0bd0???please help
will this work everytime i find one for sale it says it works on 0bd1-2 cars and i have a 0bd0 so can i use this or not any info is welcomed thanks......
Old Feb 19, 2004 | 05:13 AM
91tegrals's Avatar
somebody has to know...
Old Feb 27, 2004 | 02:02 PM
91tegrals's Avatar
some body ******* please just help me this is the last part i need so help me and yes i did search.....
Old Feb 27, 2004 | 03:12 PM
RAWB's Avatar
Default Re: missing link on a 91 teg 0bd0???please help (91tegrals)
I don't know if you can get it to work, cause the OBD1/2 car's MAP is mounted on the TB, since our OBD0's MAP is on the firewall the missing link is designed to just go INLINE with the vacuum line, whereas the OBD1/2 bolts directly on the MAP.
You can always just use the aquarium check valves instead- costs like $1 vice $50 for the fancy MISSING LINK.
Old Feb 27, 2004 | 03:59 PM
CRX T-Si's Avatar
Default Re: missing link on a 91 teg 0bd0???please help (RAWB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAWB &raquo;</TD></TR><TR><TD CLASS="quote">You can always just use the aquarium check valves instead- costs like $1 vice $50 for the fancy MISSING LINK.</TD></TR></TABLE>
DON'T DO IT MAN.
If your going to get the check valve then get the missing link no cheap *** aquarium things. That **** stays with the fishes. Spend the $50 bux and get the missing link.
And to answer your question, it's a no.
This is the OBD1 one where it's inline vs
You will have to get the second one unless you have a newer type TB.
Old Feb 28, 2004 | 12:07 AM
RAWB's Avatar
Default Re: missing link on a 91 teg 0bd0???please help (CRX T-Si)
All the MISSING LINK is is a fancy check valve. If the guy just needs to get his car running- there's no difference other than show between the 2.
Old Feb 28, 2004 | 01:21 AM
TKBLAZER's Avatar
if you want one for your car find a synapse dealer and the part number you need is ML002 retail is around $60 but i'm sure you can find them cheaper
Old Feb 28, 2004 | 07:33 PM
CRX T-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAWB &raquo;</TD></TR><TR><TD CLASS="quote">All the MISSING LINK is is a fancy check valve. If the guy just needs to get his car running- there's no difference other than show between the 2.</TD></TR></TABLE>
Bro your like comparing a screw and a tie strap. Both would work but one would actually work better.
Old Feb 28, 2004 | 11:15 PM
RAWB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">
How would it work better, they both do the EXACT same thing. I ran both and both did the purpose- avoided a CEL.
Old Feb 29, 2004 | 07:45 AM
CRX T-Si's Avatar
I do not wish to argue so believe what you believe.
Old Feb 29, 2004 | 09:41 AM
RAWB's Avatar
I'm not arguing, all I'm saying is a Missing Link is basically a fancy checkvalve. If this is the only thing keeping this mans car off the road, by all means use a couple aquarium check valves, it ain't gonna hurt anything.
Tr0LL
Jan 4, 2008 09:25 AM
D15Bbigred
Feb 21, 2006 07:57 AM
TheIntegraGuy
Jul 15, 2005 08:37 AM
DeL SLo
Jul 20, 2003 11:12 AM
RuthlessEF-9
Dec 8, 2002 01:36 AM
