hard break in method.
Old Feb 16, 2004 | 08:52 AM
Soon_2b_evil's Avatar
Default hard break in method.
ok maybe this should be in the Tech section but i wanted to know how many people in the F1 section has done the Hard Break in Method?
the only one i know is BodykitsNW that has done it.
he drove it in the parking lot and then str8 to the dyno with 20miles on his fresh built motor and laid down high 300hp close to 400hp.
Old Feb 16, 2004 | 08:59 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: hard break in method. (Soon_2b_evil)
http://www.mototuneusa.com/break_in_secrets.htm
first, let the motor heat cycle 8 times, retorque the head, then go to dyno..2 dyno passes 1/3rd throttle, 2 passes 1/2 throttle, 2 passes 3/4 throttle, then go to town
Old Feb 16, 2004 | 09:02 AM
Flamenco-T's Avatar
Default Re: hard break in method. (SIXTYdashONE)
The key to break in I believe adding load, wether you do easy or hard break in, you 'll want to add load as it goes up the RPM and let off the throttle and let the engine speed slow down on its own instead of downshifting or hitting the brakes.
For example,
Start at 2nd gear, drive it until 6000-7000 rpm ish, then let off the throttle, let the engine speed slow down naturally.., and do it again, this way, you're adding laod to the car and let the rings settles faster.
stan
Old Feb 16, 2004 | 09:10 AM
Default Re: hard break in method. (Flamenco-T)
interesting 2nd gear pull and just let it come down itself.
Old Feb 16, 2004 | 09:11 AM
HybridKOOP's Avatar
I know everyone lies about their break in.
"yeah I did 750 miles of constant variation" blah blah...
I did a nice RPM fluctuation for about 100 miles, changed the oil, and went to the track. Three years later and about 40k miles, the car still runs 12's N/A, using all Honda parts.
Old Feb 16, 2004 | 10:03 AM
Default Re: hard break in method. (HybridKOOP)
yeah maybe do the 2nd gear pulls for about 100miles. I could do that in one day.
Old Feb 16, 2004 | 02:26 PM
IntegracinGSR's Avatar
How high in the RPM's are you guys going when you do these second gear pulls?
Old Feb 16, 2004 | 02:54 PM
Nid Styles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">http://www.mototuneusa.com/break_in_secrets.htm
first, let the motor heat cycle 8 times, retorque the head, then go to dyno..2 dyno passes 1/3rd throttle, 2 passes 1/2 throttle, 2 passes 3/4 throttle, then go to town</TD></TR></TABLE>
Great site!
Old Feb 16, 2004 | 03:04 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: hard break in method. (nd_styles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nd_styles &raquo;</TD></TR><TR><TD CLASS="quote">
Great site! </TD></TR></TABLE>
Old Feb 16, 2004 | 04:20 PM
Johnyquest's Avatar
Default Re: (IntegracinGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegracinGSR &raquo;</TD></TR><TR><TD CLASS="quote">How high in the RPM's are you guys going when you do these second gear pulls?</TD></TR></TABLE>
Read the link posted above. "MotoMan" details the breakin method step by step. It's really easy and it really works.
Good luck.
Old Feb 16, 2004 | 05:04 PM
-iLLuZioN-B18C1's Avatar
ive never tried the hardbreakin process. but the soft one seems to work as well, its what i did. i just drove my car to 3-3.5k for 1000 miles. as for oil, i changed it after the initial start up, and after 250 miles, then again at 500, then again at 1000, usuing the cheaper oil. then put synthetic in at 1000.
im getting 180 across the board on a 9.1 CR motor.
Old Feb 16, 2004 | 05:05 PM
Cyber ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">The key to break in I believe adding load, wether you do easy or hard break in, you 'll want to add load as it goes up the RPM and let off the throttle and let the engine speed slow down on its own instead of downshifting or hitting the brakes.
For example,
stan</TD></TR></TABLE>
but what happens if your car hasnt tuned yet ?? wouldnt the engine blow up right away , specially revving it to 6-7k ?
thanks
Old Feb 16, 2004 | 05:17 PM
FredoSP's Avatar
Default Re: hard break in method. (Day Walker)
no cause if there is no load on the engine I can be in 2nd gear @ 8000 rpm and still be in VAC, not boost.
Old Feb 17, 2004 | 11:22 AM
ttt
Old Feb 17, 2004 | 11:26 AM
Muckman's Avatar
Moderator in Chief
Default Re: hard break in method. (FredoSP)
so your talking about high rpm with very little throttle?
Old Feb 17, 2004 | 11:27 AM
HXMan's Avatar
Anyone use break in oil?
Old Feb 17, 2004 | 11:30 AM
nevin's Avatar
i tried it. It works. I did wot pull and let the engine rev down with less then 10 miles on it. I honestly dont think it very likely you will break anything breaking it in hard.
Old Feb 17, 2004 | 12:06 PM
BodyKits NW's Avatar
Default Re: (nevin)
You can do it!!
Old Feb 17, 2004 | 12:39 PM
Kelly.'s Avatar
I've quit using this account
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
this is how i did it. i used non detergent 30w iol for break in (got the oil at napa).
after less then 25 miles on it, i had 152 psi +/- 2 across all 4 cylinders. (9.0-1 c/r on a sohc @ 6500 ft up) now when i drive it around town i vary the throttle and will continue to do so for another 200 miles.
its all about putting a load on the rings so they seal right.
Old Feb 17, 2004 | 06:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">no cause if there is no load on the engine I can be in 2nd gear @ 8000 rpm and still be in VAC, not boost. </TD></TR></TABLE>
thats interesting
Old Feb 17, 2004 | 06:34 PM
This One's Avatar
its funny, im a firm believer in the theory of this break in method....
but i just got done putting my motor back together and it sure is hard to commit myself to go out and jump on it with 25 miles on it..
Imma give it a couple hundred miles to make sure everything is cool and then go to town.
I just wanna give the motor some time to get used to itself
Old Feb 17, 2004 | 06:37 PM
FredoSP's Avatar
hey guys, maybe my comments were ambiguous, I wanted to state the point that even if you rev high you still need load, b.c like i said I can be in 2nd gear @ 8k and still be in VAC.
Maybe Ben can add some good points. I remember him saying this at the EFI101 class.
Old Feb 17, 2004 | 06:47 PM
HT's Biggest Loser
To follow up to what Fred is sayin, just look at it like this..
Revving to 8k in 2nd gear going UPHILL will put alot more load on a car rather then going downhill at 8k in 2nd gear. On a dynojet, there is no load...on a dynopack, there is load capabilities.
Old Feb 17, 2004 | 07:15 PM
Flamenco-T's Avatar
or you can date a heffer like sixtydashone did, take her out on your car and that adds up more load and your rings will seated twice as fast.. lol
stan
Old Feb 17, 2004 | 07:18 PM
HT's Biggest Loser
Its quite disturbing that you would talk about your own mother like that stan.. Tisk Tisk
