In need of new pistons, but which ones?
Old Feb 16, 2004 | 09:01 AM
PBrex's Avatar
Default In need of new pistons, but which ones?
I'm new to the whole Turbo world. I recently bought a DOHC ZC motor for my '91 HF. I'm planning on dropping in a turbo. My questions are as follows.
1. Which pistons would be good to use for 5-12 psi? To my understanding, the ZC has a cr of 9.6:1. I've heard on this board and others that when you boost, you should use lower compression on the motor.
2. Would it be better to use say 9.1 pistons and/or use thicker head gasket? Are there any drawbacks on the head gasket (i.e. bigger chance of blowing the gasket?)
3. Would a properly tuned turbo ZC pass smog inspection? with the motor being lower compression, would anything besides power output change if I were to turn the boost all the way down?
4. What kinds of setups are some of you running (if any of you are running turbo ZC's)?
I know these are newbie questions, but like I said I'm new to turbos and just want to get my facts straight before diving into the motor head first. I did a search and alot of the answers were a bit skewed. Thanks in advance.
Old Feb 16, 2004 | 09:30 AM
94gsr4dr's Avatar
Default Re: In need of new pistons, but which ones? (PBrex)
If i were you i would see if cp makes an application for your motor, and if you are so keen on running 9:1 compression i would get pistons rated at that then getting 9:5 and using a a thick headgasket.
Contact Earl on this site, if cp makes one for your application.
Old Feb 16, 2004 | 09:37 AM
PBrex's Avatar
Default Re: In need of new pistons, but which ones? (94gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">If i were you i would see if cp makes an application for your motor, .</TD></TR></TABLE>
who's cp? I assume they make aftermarket pistons.
Old Feb 16, 2004 | 09:59 AM
94gsr4dr's Avatar
its a company, much like je, but i have a personal preference of them over je's
Old Feb 16, 2004 | 10:49 AM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">If i were you i would see if cp makes an application for your motor, and if you are so keen on running 9:1 compression i would get pistons rated at that then getting 9:5 and using a a thick headgasket.
Contact Earl on this site, if cp makes one for your application.</TD></TR></TABLE>
elvis3000
May 22, 2010 09:47 AM
black.zc.turbo
Feb 19, 2009 01:41 PM
jtmoney2002
Aug 17, 2008 09:38 AM
oldskool88291
11
Dec 31, 2007 06:29 AM
cr-x si
Dec 19, 2002 02:20 PM
