N20 PEOPLE
Old Feb 18, 2004 | 10:17 AM
dc2_and_ef's Avatar
Default N20 PEOPLE
when building a motor for nitrious, what should be taken care of (100-150 direct port shot)?
Old Feb 18, 2004 | 10:21 AM
J337_UNIT's Avatar
Default Re: N20 PEOPLE (dc2_and_ef)
forged pistons,rods, block guard, maybe even a sleeve job.. definately high flow fuel pump and fpr and bigger injectors.
Old Feb 18, 2004 | 10:25 AM
Kataku2K3's Avatar
Spencer (BoredNStroked) is setting up his new LSVTEC motor for ~200-300 progressive and we built it just as any other high boost FI motor... I would recommend sleeving it, but at the bare minimum swap out the pistons for some forged slugs, and some aftermarket rods... Headwork, that's sort of up to you... Spencer is running a stock head but if you got the money Portflow is nice Stock sleeves should handle 150 just fine but you will want forged pieces... I would just sleeve it but what block are you working with anyway? Just my $0.02
Old Feb 18, 2004 | 12:17 PM
dc2_and_ef's Avatar
what about s\s valve's
Old Feb 18, 2004 | 12:21 PM
Kataku2K3's Avatar
Default Re: (dc2_and_ef)
As you know nitrous creates a lot of heat so aftermarket valves would be good too... If you sent a head out to Portflow and had it fully done (just as a turbo of full blown NA) that's all you need... It's the bottom end I would really worry about...
bumblebee-tec
Jul 15, 2007 10:29 PM
exratedaccord93
Apr 30, 2005 09:21 AM
Dammit_Dan_954
Nov 26, 2003 02:29 AM
H23 Power
Apr 21, 2003 09:58 AM
rOby
Jul 23, 2002 01:43 PM
