non- mandrel bent ok????
Old Feb 16, 2004 | 09:07 PM
blackeg's Avatar
Default non- mandrel bent ok????
i came across these intercooler pipes the other night. it seemed like a real good deal, till i saw that they werent mandrel bent. at least they are not crush bent. would it be recommend to only use mandrel pipes, or will these do the job? just not sure of this one. the turbo will be a t3 60 trim with a johnnyracecar 5 inch i/c on a d16z6. planning to run around 7 or 8 psi to start, then eventually up to 12 or so. whats your opinions on this???
http://cgi.ebay.com/ebaymotors...33742
Old Feb 16, 2004 | 09:14 PM
Johnyquest's Avatar
Default Re: non- mandrel bent ok???? (blackeg)
My opinion on this comes in two parts:
1) They will be fine if you choose to buy them. Mandrel isn't all that impt, especially on charge pipes, as long as they are 2" or above.
2) You can duplicate that WITH mandrels and all (www.jcwhitney.com) for less money and probably get a better fit (they never fit just right... ever).
Good luck.
Old Feb 16, 2004 | 09:49 PM
infamousR13's Avatar
Mandrel is the best, but get what you can afford.
Old Feb 16, 2004 | 10:56 PM
zip's Avatar
zip
Check out the k-teller intercooler pipes:
http://www.kteller.com/store/i...6_112
Old Feb 17, 2004 | 12:58 AM
808b18c1boosted's Avatar
Default Re: non- mandrel bent ok???? (zip)
Is there a contact # for kteller.
Old Feb 17, 2004 | 03:54 AM
Chillinit's Avatar
Default Re: non- mandrel bent ok???? (808b18c1boosted)
Old Feb 17, 2004 | 04:13 AM
RedTegLS's Avatar
Default Re: non- mandrel bent ok???? (Chillinit)
Kteller8 stuff is very nice. Mandrel bends are VERY important. A 2.5" maybe even a 2.25" mandrel pipe will out flow a 3" crush bent pipe all day.
Old Feb 17, 2004 | 04:51 AM
ScrapinSi's Avatar
Will that KTeller kit work with a 2000 Si w/ a Spearco i/c?
Old Feb 17, 2004 | 05:09 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: non- mandrel bent ok???? (ScrapinSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi &raquo;</TD></TR><TR><TD CLASS="quote">Will that KTeller kit work with a 2000 Si w/ a Spearco i/c? </TD></TR></TABLE>
i belive it has custom kits on there...
check it out, or just send him an IM
Old Feb 17, 2004 | 07:24 AM
igo4bmx's Avatar
just to let you know, stackz here from honda-tech is that seller on ebay!
Old Feb 17, 2004 | 12:57 PM
blackeg's Avatar
Default Re: non- mandrel bent ok???? (RedTegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote"> Mandrel bends are VERY important. A 2.5" maybe even a 2.25" mandrel pipe will out flow a 3" crush bent pipe all day.</TD></TR></TABLE>
wow man that much more of a difference than i expected. so would these pipes fit somewhere in the middle of that, considering the bends are smooth, but do not maintain the same diameter?
Old Feb 17, 2004 | 01:14 PM
TurboJesse
Guest
Posts: n/a
I know what kinda bender your talking about (ie. not krinkle bent). I honestly don't think you will notice any real difference on a mild setup. If all out power is what your going for then thats another thing, but it will work fine for most setups.
Old Feb 17, 2004 | 07:54 PM
blackeg's Avatar
Default Re: non- mandrel bent ok???? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">I know what kinda bender your talking about (ie. not krinkle bent). I honestly don't think you will notice any real difference on a mild setup. If all out power is what your going for then thats another thing, but it will work fine for most setups.</TD></TR></TABLE>
yea man im not lookin for all out power, especially not at first cause it will be stock bottom end. sounds good then
Old Feb 17, 2004 | 08:00 PM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">till i saw that they werent mandrel bent. at least they are not crush bent.</TD></TR></TABLE>
if they are not mandrel bent, they are crush bent.
I know many people running crush bent charge pipe. it's just not as efficient as mandrel bent, but it will work fine.
wfocrx
Jul 19, 2006 08:45 AM
smiths54aub
Mar 11, 2005 08:26 PM
Irishweird00
Dec 18, 2003 04:41 PM
integranator
Mar 2, 2003 07:11 AM
