question about 5 bolt downpipe
Old Feb 17, 2004 | 07:16 PM
g5r's Avatar
g5r
Default question about 5 bolt downpipe
if i only bolt on 4 or the 5, would that cause any problem? the fifth one is on the part that bend down, so it is very tight to do anything. Also should i copper spray the gasket between manifold and turbo?
Old Feb 17, 2004 | 07:19 PM
rtype11's Avatar
Default Re: question about 5 bolt downpipe (g5r)
then on the fifth hole, put a stud into the turbine housing and nut it up, you can buy a gasket from Ford if its the same one I am thinking about, but if the flange is high quality and flat just copper spray or nothing should be just fine.
Old Feb 17, 2004 | 07:20 PM
highboostb18c1's Avatar
i only used 2 bolts
Old Feb 17, 2004 | 07:26 PM
g5r's Avatar
g5r
Default Re: question about 5 bolt downpipe (highboostb18c1)
yea i have a stud on the turbo but i cant fit the nut on there(no space). i guess 4 bolts is good enough, i dont want no leak.
Old Feb 18, 2004 | 05:25 AM
g5r's Avatar
g5r
ttt, doing turbo today need to know
Old Feb 18, 2004 | 07:55 AM
WONG FRIED RICE's Avatar
yea 4 bolts good enough, but 5th would be nice?
tony n.
May 25, 2005 04:50 PM
BoostedB20A
Feb 12, 2003 06:14 PM
400WHPITR
Feb 1, 2003 07:40 PM
udctown
Jul 11, 2002 01:36 PM
