Wategate, and exhast return ?'s
Old Feb 18, 2004 | 11:11 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Wategate, and exhast return ?'s
Basicly, on a external wastegate setup.. whats the negitives of not tapping the exhaust into the down pipe?
a loud as exh leak? since its soo close to the manifold, flames? unbareable heat?
is it something that is do'able? always T in your exh.? what do you guys think?
Old Feb 18, 2004 | 11:16 AM
DaX's Avatar
DaX
Loved
Community Favorite
Are you talking about the dump tube off the WG?
Old Feb 18, 2004 | 11:18 AM
RedTegLS's Avatar
Default Re: Wategate, and exhast return ?'s (Built B16A)
I think the only downside of not running your dump tube into your exhaust is......wait THERE ISNT ONE! It doesnt sound like a leak at all. Just a loud whoosh from full boost to redline.
Old Feb 18, 2004 | 11:19 AM
DaX's Avatar
DaX
Loved
Community Favorite
The only downside to NOT running a dump tube whatsoever is melting stuff in the way of the exhaust gas [if there is anything]. Just make sure all hoses are not in front of the WG port.
Old Feb 18, 2004 | 11:25 AM
twkdCD595's Avatar
Default Re: (DaX)
just make sure the wastegate discharge port is not pointing toward or in close proximity to anything that can melt or catch fire.
a cheap dump tube to point it to the ground is as far as I would go.
Old Feb 18, 2004 | 11:47 AM
Built B16A's Avatar
Default Re: (twkdCD595)
ok.. so somehow.. the discharge of the WG isnt' all that loud? a pipe aim'ing it downwards would be fine? you dont' HAVE to tap it inot the exhaust steam?
i just didnt' want it to be loud as all hell. like an exhaust leak.
Old Feb 18, 2004 | 11:56 AM
TrueNorthStar's Avatar
There is the smell..... but to some that is a good thing.
Old Feb 18, 2004 | 11:57 AM
DaX's Avatar
DaX
Loved
Community Favorite
Most people don't bother recirculating the WG dump. Most people either run open wastegate or a wategate with a dump tube [just pointing toward the ground].
Old Feb 18, 2004 | 12:00 PM
BROOD's Avatar
Downsides are more of an opinion issue....IMO the downsides to an open dump tube is:
~the dang dirty engine bay
~the exhaust smell after a short drive
~the increase in exhaust volume when the WG is open
I perticularly do not like open dumps on my car especially if it's a street car. But if you plan to route back to the exhaust merge the dump into the downpipe at least 18"-20" behind the turbine outlet. Good luck
Old Feb 18, 2004 | 12:02 PM
Built B16A's Avatar
Default Re: Wategate, and exhast return ?'s (BROOD)
hrmm... well.. maybe i'll just make a small dump tube and locate it somewhere close to the oil pan.. that way almost all of it would be out of the engine bay.
turboteg90
Nov 25, 2007 04:43 PM
_Endless_
Apr 27, 2007 07:21 AM
B20-T
Feb 18, 2003 01:05 PM
Quick 200k Mile Motor
Nov 10, 2002 03:08 PM
Damon B.
Nov 27, 2001 01:25 PM
