should i hear spool efore i see boost?
Old Feb 18, 2004 | 07:41 AM
r1lorenzini's Avatar
Default should i hear spool efore i see boost?
i hear my turbo spooling but the boost is not yet being shown on the guage? my vacuum works well but the boost side is only going to about 2-3psi? it feels like its pulling really well. maybe i am just underestimating what 2-3 good lbs feels like?
Old Feb 18, 2004 | 07:43 AM
RedTegLS's Avatar
Default Re: should i hear spool efore i see boost? (r1lorenzini)
I hear mine spool louder before I boost. Once your at full boost you should only hear wastegate.
Old Feb 18, 2004 | 08:30 AM
m R g S r's Avatar
Default Re: should i hear spool efore i see boost? (RedTegLS)
Mine was the same way. My turbo was louddd!
Old Feb 18, 2004 | 11:19 AM
Egg-weezy's Avatar
Default Re: should i hear spool efore i see boost? (m R g S r)
What turbo are you using? Are you using a boost controller of any kind? The reason I ask is because you say your only getting 2-3 psi which is low unless you've turned the boost down. Maybe you should check the vaccum lines going to the boost controller and check for leaks too. Other than that, you could be hearing the wastegate either stuck open or a bearing could be going too. I'm using a 14B turbo and I can here it alittle before it boost but when it does boost is where you here it the most. I GUESS IT COULD BE ALOT OF THINGS WRONG. Or maybe nothing is wrong at all. good luck. Post why you're only hitting 2-4 pounds of boost. (wastegate?boost controller?)
Old Feb 18, 2004 | 11:22 AM
psi420's Avatar
Maybe I am ignorant in asking this, but you can only set your lowest boost to whatever the spring (wastegate) is set at.
Correct?
You cant use a boost controller to get you to boost 5psi if you have a 7psi spring?
Old Feb 18, 2004 | 11:26 AM
DaX's Avatar
DaX
Loved
Community Favorite
Correct.
Old Feb 18, 2004 | 11:33 AM
Egg-weezy's Avatar
Default Re: (DaX)
your exsactly right on the Wastegate ??. That's why I want to know what turbo he's using to hit only 2-3psi. Which leads me to believe that something else is wrong.
Old Feb 18, 2004 | 12:18 PM
blown_LS's Avatar
Default Re: (dainteg)
I hear turbo spool up before actually its' boostimg. It was on my integra now same thing on my dsm.
Old Feb 18, 2004 | 12:20 PM
Cramerox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dainteg &raquo;</TD></TR><TR><TD CLASS="quote">your exsactly right on the Wastegate ??. That's why I want to know what turbo he's using to hit only 2-3psi. Which leads me to believe that something else is wrong. </TD></TR></TABLE>
unless he has a 3 lbs spring...which i was running at one point.
Old Feb 18, 2004 | 03:10 PM
uhm well no boost controller only have the stock greddy tdo4 kit with trust intercooler so maybe my guage has a leak thats what i think cuz damn my shiet feels really really good for only 3 lbs????
Old Feb 18, 2004 | 03:18 PM
Dengar's Avatar
Default Re: (r1lorenzini)
Check all the piping connections.. I blew off my piping the second night I had my turbo and you could hear the turbo spooling louder than ever. I only saw about 2 or 3 psi of boost also, until I found a really bad connection in the charge piping. 2 or 3 psi felt good, that was until I was running a full 7.
Bottom line is go check all your piping connections. If you are running a greddy kit you should be seeing 6 or 7 on the boost gauge.
Old Feb 18, 2004 | 03:28 PM
Hoosier Daddy's Avatar
Default Re: (Dengar)
Check your piping and make sure your boost gauge is reading correctly. Maybe your vacuum line is T'd in too many places and the gauge isn't getting an accurate reading.
Old Feb 18, 2004 | 03:43 PM
ProEater's Avatar
Default Re: (Hoosier Daddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy &raquo;</TD></TR><TR><TD CLASS="quote">Check your piping and make sure your boost gauge is reading correctly. Maybe your vacuum line is T'd in too many places and the gauge isn't getting an accurate reading.</TD></TR></TABLE>
thats what it sounds like to me
Old Feb 19, 2004 | 10:12 AM
Egg-weezy's Avatar
Default Re: (ProEater)
So its for sure that you have a leak in the system somewhere. but this doesn't sound like the piping because you say you feel pretty good when it boost. That means that it has to be somewhere in the vaccum or falty gauge.
Old Feb 19, 2004 | 11:05 AM
blown_LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dengar &raquo;</TD></TR><TR><TD CLASS="quote">Check all the piping connections.. I blew off my piping the second night I had my turbo and you could hear the turbo spooling louder than ever. </TD></TR></TABLE>
Hmm. I know that hapend to me but turbo could not spool up at all.
Old Feb 19, 2004 | 11:15 AM
dc2b18c1gsr's Avatar
Default Re: (blown_LS)
type WAHHHHHH pshhhhhhhhhh, wah pshhhh
Old Feb 19, 2004 | 11:26 AM
ForceThis!'s Avatar
Default Re: (dc2b18c1gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2b18c1gsr &raquo;</TD></TR><TR><TD CLASS="quote">type WAHHHHHH pshhhhhhhhhh, wah pshhhh</TD></TR></TABLE>
no, no, no, vrrrrrroooom pfffFFFfffttt
Old Feb 19, 2004 | 11:54 AM
Egg-weezy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blown_LS &raquo;</TD></TR><TR><TD CLASS="quote">
Hmm. I know that hapend to me but turbo could not spool up at all. </TD></TR></TABLE>
this happen to me and that's what happen to me. the turbo would spool every time i got on the gas. Don't confuse turbo spool with reading boost.
0618turbocivic
Jul 16, 2006 03:46 PM
bodea_florian
Aug 25, 2004 06:54 PM
incognitoracerr
Jan 10, 2003 05:42 PM
Snafu-Si
Mar 5, 2002 02:07 AM
Cyrio
Dec 4, 2001 07:00 PM
