Socketing p72 for Hondata
Old Feb 18, 2004 | 05:30 PM
B18Flip's Avatar
Default Socketing p72 for Hondata
I decided to try socketing my usdm p72 for Hondata ....so far i have the 20 pin chip and 28 pin IC socket soldered in. Next step is to solder in plug for CN2 1-4, cut the J12 jumper and bridge J1 right? Sorry this is my first go at it but so far so good
Old Feb 18, 2004 | 05:45 PM
HXMan's Avatar
Default Re: Socketing p72 for Hondata (B18Flip)
Good luck...I don't trust myself doing that.
Old Feb 18, 2004 | 05:50 PM
oemDC2's Avatar
Default Re: Socketing p72 for Hondata (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">Good luck...I don't trust myself doing that.</TD></TR></TABLE>
Yeah, i didnt want to screw up so i took mine to hondata and had them do it. Good luck with it.
Old Feb 18, 2004 | 06:14 PM
B18Flip's Avatar
lol yeah, i'm making sure to take my time. I think the desoldering part is a lot harder than the actual soldering though. Oh yeah, I have 2 different resistors that came w/ the hondata....what resistance are they??
Old Feb 18, 2004 | 06:38 PM
Flamenco-T's Avatar
yes, desoldering is harder than soldering itself, just make sure you have a good flux and thin wires, so you can control the melted solder..
stan
Old Feb 18, 2004 | 06:46 PM
Seraph0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">
lol yeah, i'm making sure to take my time. I think the desoldering part is a lot harder than the actual soldering though. Oh yeah, I have 2 different resistors that came w/ the hondata....what resistance are they?? </TD></TR></TABLE>
The one with a single black stripe is a 0 ohm resistor. It is used for J1.
Old Feb 18, 2004 | 07:00 PM
B18Flip's Avatar
Default Re: Socketing p72 for Hondata (MarkC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MarkC &raquo;</TD></TR><TR><TD CLASS="quote">
The one with a single black stripe is a 0 ohm resistor. It is used for J1.</TD></TR></TABLE>
Thanks MarkC Do i need the resistor with the 3 stripes? I had a p28 socketed once and i remember that one was left out...
Old Feb 18, 2004 | 09:04 PM
Seraph0's Avatar
From looking closely at your picture I don't see the normal spot for that resistor. It normally goes right next to J1. (It's either R52 or R54). If you don't have a spot on the board for it you don't have to use it.
Old Feb 19, 2004 | 04:06 AM
B18Flip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MarkC &raquo;</TD></TR><TR><TD CLASS="quote">From looking closely at your picture I don't see the normal spot for that resistor. It normally goes right next to J1. (It's either R52 or R54). If you don't have a spot on the board for it you don't have to use it.
yup, r52 then...its diagonal to J1. It's kinda cutoff in the picture Thanks again Mark
Old Feb 19, 2004 | 04:17 AM
cornbread's Avatar
Damn dude you didn’t waist any time getting to work on this, i just sold you the hondata a few hrs ago . Good luck with the project and hope to see you boosting around town in the spring.
Old Feb 19, 2004 | 07:03 AM
B18Flip's Avatar
Default Re: Socketing p72 for Hondata (cornbread)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cornbread &raquo;</TD></TR><TR><TD CLASS="quote">Damn dude you didn’t waist any time getting to work on this, i just sold you the hondata a few hrs ago . Good luck with the project and hope to see you boosting around town in the spring.</TD></TR></TABLE>
heehee yeah, i gotta get going on my project because my tunning app. w/ boostedhybrid is coming up
Old Feb 19, 2004 | 08:16 AM
HXMan's Avatar
Default Re: Socketing p72 for Hondata (oemDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oemDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, i didnt want to screw up so i took mine to hondata and had them do it. Good luck with it.</TD></TR></TABLE>
So hondata still does this? I had them do it like 3 years ago with my old ecu, but I wasn't sure if I would have to have a dealer chip the ecu for me or not.
Old Feb 19, 2004 | 11:58 AM
B18Flip's Avatar
So hondata still does this? I had them do it like 3 years ago with my old ecu, but I wasn't sure if I would have to have a dealer chip the ecu for me or not.</TD></TR></TABLE>
i think so, the website said $65 the last time i checked it. But most dealers or tuners socket them cheaper
Old May 27, 2004 | 08:29 AM
93H22ACX's Avatar
hey can you post those pictures up again....i'll like to see so i can socket mine
Old May 27, 2004 | 12:06 PM
B18Flip's Avatar
Default Re: Socketing p72 for Hondata (93H22ACX)
sure, np man. I lost the pics since my comp had a virus but i'll retake the pics later tonight
Old May 27, 2004 | 12:09 PM
93H22ACX's Avatar
please do...i need it bad
Old May 27, 2004 | 02:14 PM
turbo*s2k's Avatar
i think so, the website said $65 the last time i checked it. But most dealers or tuners socket them cheaper </TD></TR></TABLE>
Some dealers try to jack you on the socketing.
Old May 27, 2004 | 05:33 PM
DaX's Avatar
DaX
Loved
Community Favorite
What are you using to desolder? A desoldering gun or a wick?
Old May 27, 2004 | 05:58 PM
oemDC2's Avatar
I paid $50.00 to have them socket my ecu..
Old May 28, 2004 | 04:07 PM
B18Flip's Avatar
Ok this is how i socketed my p72.... i don't know all the technical jargon so bare w/ me
1) Bridging J1- Desolder and solder in the resistor w/ the single stripe
2) Desolder then solder in the socket with the little notch facing the harness, then place the chip on the socket with the notch in the same direction.
3) Desolder and solder in that chip in the same manner with the notch facing the harness
4) Only desolder #'s 1 through 4, then solder in that socket with the tab facing out towards the ecu wall
5) ** not in picture** locate jumper J12 and cut it out
6) test it out to see if you get a light in the hondata unit
**TRY THIS AT YOUR OWN RISK , AND TAKE YOUR TIME!!**
Old May 29, 2004 | 02:38 AM
93H22ACX's Avatar
is this that white piece with 4 pins?
Old May 29, 2004 | 05:52 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22ACX &raquo;</TD></TR><TR><TD CLASS="quote">
is this that white piece with 4 pins?</TD></TR></TABLE>
Yes.
B18flip...this may sound dumb...but i can't find the LED on my S200 box...where in the hell is it? [I haven't tried plugging it into the harness yet]
Old May 29, 2004 | 06:05 AM
Rory Breaker's Avatar
Default Re: Socketing p72 for Hondata (DaX)
On the S200's its a light inside the box. You see it through a hole on the case.
Old May 29, 2004 | 03:51 PM
DaX's Avatar
DaX
Loved
Community Favorite
But the only "hole" in my case that I can see is through the crack around where the wires plug in. Am I supposed to see it through there?
Old May 29, 2004 | 07:12 PM
Jaker's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote"> Am I supposed to see it through there?</TD></TR></TABLE>
Yup!
jwyndsdime
Mar 26, 2007 07:25 PM
racingfan
Jul 7, 2006 02:43 AM
JDMTRSPORTS
10
Apr 5, 2006 10:52 AM
breakneckvtec
Jan 20, 2004 06:48 AM
ludelvr
Jun 20, 2003 12:39 PM
