Greddy upgrade
TD04H-15G....well the next logical step is definately the T88. Let's see, 1.6 liters, 7200 redline... you'll probably have approximately 100RPM of boost. Probably around a pound or so...
ARE YOU SERIOUS?
....are you planning on upgrading the turbo? None of the options you listed will work. They won't even come close to fitting on the manifold, or spooling. I think you need to go do more homework.
ARE YOU SERIOUS?
Anything a standard Garrett T25 turbine housing will fit. Keep the compressor under a .60a/r T3 or it won't fit either. Keep in mind, the wacky 4 bolt discharge will have to be thrown away. You will need an all new outlet/downpipe. These are all good things. More homework...
T88....
T88....
yes it does... have fun finding one outside of a kit. Also, the same thins apply. New outlet/DP. The TD05H-18G has a standard garrett T25 turbine housing...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JalopySiR »</TD></TR><TR><TD CLASS="quote">yes it does... have fun finding one outside of a kit. Also, the same thins apply. New outlet/DP. The TD05H-18G has a standard garrett T25 turbine housing...</TD></TR></TABLE>
every once in a while they pop-up on ebay and in the classifieds.
I have a 18g for sale with a 11psi actuator that you might be interested in. check out my link:
https://honda-tech.com/zerothread?id=771648
A DSM 18G will not fit....
A GREDDY 18G will fit.
A GREDDY 18G for the DOHC engines has a T25 turbine housing.
A DSM 18G has a mitsubishi turbine housing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekVanger »</TD></TR><TR><TD CLASS="quote">turbonetices t3/t04e</TD></TR></TABLE>
no that is a T3 flange not a T25, get a 18g you won't be dissapointed or get a new mani and get a T3/T4
He is talking about the Greddy TD05H-18G from the DOHC kit, I hope. That unit, and that unit alone, will fit because it has a standard T25 hot side.
Can we make this a sticky, please? I have answered this question WAY too many times this month alone.
That manifold does not have a T25 Flange on its manifold or the Turbo. Greddy uses its own specs for the B-series turbo kits that it makes. It's closer to a 8sq cm flange, which is closer to a T3, but off by approx. 2.5mm..
You can take the 15G housing and could possibly rebuild it to a slightly larger T28 sized impeller, so that it can push a little more CFM. It would be considered to be a mitsubishi 19C or close to it.
Turbochargers.com is an authorized Greddy Rebuild dealer, and can upgrade those to larger specs..
Skadaloz
Jun 21, 2009 06:37 PM
yellowturbo
Oct 24, 2003 09:51 AM
