eagle rod questions
Old Feb 16, 2004 | 06:22 PM
boostedsolv10eater's Avatar
Default eagle rod questions
i have eagle rods for a b18, few things dosnt 28lbs seem kinda low for the arp torque setting? also i have heard somethings about eagle rods with the arp bolts about them being pressed or need to be pressed. not sure what the guy was really talking about, anyone else hear anthing about it? any ideas are welcome
thanks
Old Feb 16, 2004 | 06:31 PM
Rod.'s Avatar
Default Re: eagle rod questions (boostedsolv10eater)
No i never heard of that. What i am worrying about do they hold up. I been reading some horrifying stories on here. Maybe your question is toward how to keep them holding up instead of breaking.
Old Feb 16, 2004 | 07:26 PM
Default Re: eagle rod questions (redturbocivic)
anyone else??
Old Feb 16, 2004 | 10:38 PM
RyanEJ8's Avatar
On stock pistons the wrist pins need to be pressed in. With Eagle Rods and and aftermarket pistons like JE/SRP you can push them in by hand, they do not need to be pressed. 28 ft lbs was the recommended torque spec for mine also I believe. DO NOT use ANY other spec than what was provided with your Rod bolts. This is the reason so many have claimed problems with the Eagles that redturbocivic's post referred to. Every rod that had been sent back to Eagle was broken due to improper installation, usually improper rod bolt torquing. If you overtorque them, they will break, if they are under torqued them, they will back off and fall out, both scenerios obviously very bad. The best way to install them is to check the bolt stretch specs, but it is not required, I didn't do it for my build up because I don't have the tool. I just used a digital Snap On torque wrench, very accurate. Also, make sure to use the provided ARP lube on the bolts. Motor oil changes the torque specs!
Good luck with your build up,
Ryan
blackccoupe
Sep 26, 2009 01:24 PM
reaction360
Sep 22, 2007 05:52 PM
egvtec
Dec 12, 2005 03:49 PM
Hoosier Daddy
Oct 25, 2003 10:04 PM
Thrashin
Feb 13, 2002 08:08 PM
