JRSC Map Controller Help!
Old Feb 18, 2004 | 02:24 PM
jbs's Avatar
jbs
Default JRSC Map Controller Help!
I am purchasing a used map controller and all I'm getting is the controller itself (Black Box). While reviewing the instructions on Jackson's website, I've noticed that on #3 of the instructions, I have to install a MAP sensor spacer between the MAP sensor and the Throttle Body. I called Jackson Racing to see if I could purchase this part and the guy didn't know what I was talking about. He understood the instructions but don't see it in the parts list for this item. Anyone here who has a JRSC Map Controller recognize this part? Would you please help me out with a part number of some sort? Thanks!
Old Feb 18, 2004 | 03:02 PM
i2un's Avatar
Default Re: JRSC Map Controller Help! (jbs)
It's called a map sensor relocator. I'm guessing the person you bought the Map Controller from switched to Hondata or something of that sort and still needed the relocator.
When I get off work, I can give you the part number I used. Which is for a GSR....maybe they can reference with that? It might even be the same part and they use it on multiple vehicles.
Modified by i2un at 1:24 AM 2/19/2004
Old Feb 18, 2004 | 10:22 PM
i2un's Avatar
Default Re: JRSC Map Controller Help! (i2un)
051-845 Bracket, Map Sensor Relocation (Was like $55)
051-863 O-Ring
You'll probably need to ask them for the Hose Barb and the two 25mm(?) screws that hold it in place.
Old Feb 19, 2004 | 05:56 AM
jbs's Avatar
jbs
Thanks! I appreciate the help
Old Feb 19, 2004 | 07:39 AM
jbs's Avatar
jbs
BTW. I'm curious to know if I could run the jackson racing map controller without having this map sensor spacer/relocation bracket? What does this thing do anyway?
Old Feb 19, 2004 | 07:53 AM
Silverbeast's Avatar
No, you have to have it to run the map controller. The piece acts as a check valve.
Old Feb 19, 2004 | 07:54 AM
jbs's Avatar
jbs
Default Re: JRSC Map Controller Help! (Silverbeast)
Cool! Thanks man!
c_trick
May 29, 2010 07:06 PM
hondaeg8
Jul 29, 2005 07:41 PM
JRciv
Dec 15, 2004 10:08 PM
Pfieff
Jun 13, 2003 12:03 PM
