which FMU ratio to use with my greddy setup !
Ok . i did a search and didn't find anything helpful. I am going to be installing a greddy turbo setup on my 88 crx this weekend. I am going to be using a walbro 255 intake fuel pump. I have read that if I use a 12:1 FMU that the 255 pump can't supply enough fuel for that ratio. Do you know if this is correct or not, or do you know which I should be using. The kit is the old Greddy kit with the black box, with the T3 turbo ..
Thanks in advance
Thanks in advance
Re: which FMU ratio to use with my greddy setup ! (sleeperx)
255 intank is still way better than stock pump.
But, as many times said -> get an inline... as it can supply fuel at much higher pressures.
Re: which FMU ratio to use with my greddy setup ! (Nick7)
I know that the 255 in much better and that it would be even better to get a big inline, but my question is what ratio FMU should I get for a the T3 turbo that comes with the old greddy kit? Thanks
hotimportcrx
05-07-2005 05:08 PM
slwazgsr
10-07-2002 01:59 PM
