help! broke bolt on the compressor.
Old Feb 17, 2004 | 02:02 PM
wreckedagain's Avatar
Default help! broke bolt from down pipe to turbo.
I took my down pipe off which was never seated correctly. I just have the drag downpipe and the bolt the stays on the downpipe the entire time (because of the flange meeting to pipe) broke. Now on the turbo housing should i drill have it filled and lathed then have them redrill it. They will have to heat up the entire thing correct because of the cast??? A helicoil wont hold or atleast if i take it on and off correct? If i do take it to a machine shop what do you think that they would charge?Thanks
Modified by wreckedagain at 3:17 PM 2/17/2004
Old Feb 17, 2004 | 02:08 PM
BoostedSi's Avatar
Default Re: help! broke bolt on the compressor. (wreckedagain)
u mean the bolt broke in the turbo housing?
If the bolt is close enough to the surface you can get a dremel(put the wheel bit on it) and cut a slit on the bolt. Then use a flat head and unscrew it. Worked plenty of times for me.
Old Feb 17, 2004 | 02:16 PM
Default Re: help! broke bolt on the compressor. (BoostedSi)
yes turbo housing and it broke deep in there. I tried the dremel and cant get it to back out and then tried to drill a pilot hole and work from there but now i have a friggen mess. thanks for your help the though
95dc2teg
Nov 9, 2010 05:49 PM
allmotorb18c14door
Mar 12, 2008 12:34 PM
TurboEM1
Oct 1, 2006 05:59 PM
RobbieG35
Aug 9, 2005 09:19 AM
project dc2
Jun 5, 2004 12:53 AM
