Duty Cycle Question
Old Feb 15, 2004 | 08:32 PM
b18b1hmtlove's Avatar
Default Duty Cycle Question
Quick question
At 7950rpm at 11psi with 450cc injectors, what would you expect the duty cycle to be at a 11.5:1 A/F
Approximations is all im looking for. Thanks
Old Feb 15, 2004 | 09:00 PM
Mase's Avatar
Default Re: Duty Cycle Question (b18b1hmtlove)
you have to know a lot more than that to figure out the duty cycle and/or pulse width.
Now if you knew the pulse width, we could figure out the duty cycle
Old Feb 15, 2004 | 09:08 PM
im just looking for an approximate value. I dont know if it would help you if i told you they were DSM 450s.
Basically im trying to formulate a solid basemap and my first attempt im getting about 80% duty cycle and im thinking that is a little low for that amount of boost at that rpm and such. But i wanted to make sure. Im not looking for value a definite answer. Just a thought, an approximate, a span. something.
Thanks
Old Feb 15, 2004 | 09:13 PM
Mase's Avatar
Default Re: (b18b1hmtlove)
it totally depends on the motor, the turbo, the compression, basically you need to know the cfm at that point....
Nid Styles's Avatar
Default Re: Duty Cycle Question (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">you have to know a lot more than that to figure out the duty cycle and/or pulse width.
Now if you knew the pulse width, we could figure out the duty cycle</TD></TR></TABLE>
Old Feb 15, 2004 | 09:15 PM
Mase's Avatar
Default Re: (Mase)
I'd say on a typical gsr motor, you'll probably see 90% duty cycle around 300 whp w/ 450's. It also depends on the volumetric efficiency of the motor as well..... lots of things come into play
Old Feb 15, 2004 | 09:21 PM
okay, thanks. that helps kinda... I must not understand how duty cycle works total. I guess its time to read up and become more informed.
Basically my understanding was at the highest boost/rpm your duty cycle would be at its peak. And i was just looking for the peak duty cycle of some 450cc injectors at 7950rpm and 11.03psi to know if it should be more than 80%....i guess by you saying GSR is 90% i would expect more in that range.....
hbkxtbone
May 3, 2007 09:10 AM
lifestyledej8
Mar 29, 2007 08:54 AM
needforvtec
Jul 15, 2006 11:53 AM
whoneedzvtec
Jan 1, 2006 10:45 AM
lv6l
Oct 6, 2005 01:27 AM
