quick cath can question
Old Feb 17, 2004 | 02:16 PM
zseeanz's Avatar
Default quick cath can question
pvc to can to intake mani right? What about the valve cover vernt? Do you need to filter the air coming from there at all?
Old Feb 17, 2004 | 02:22 PM
Ek00fbp's Avatar
Default Re: quick cath can question (zseeanz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zseeanz &raquo;</TD></TR><TR><TD CLASS="quote">pvc to can to intake mani right? What about the valve cover vernt? Do you need to filter the air coming from there at all? </TD></TR></TABLE>
The pcv in the back of your block goes through a black box then goes to your intake manifold I believe. But It would be better to route that to your catch can rather than your intake manifold, then plug up the hole in your manifold. Also, your breather on the valve cover should be routed to the same catch can further releaving crank case pressure and not dumping it back into your intake. Here is the best method of doing a catch can setup on a turbo car or NA for that matter: http://www.theoldone.com/components/breather/
I have mine setup like that one except i removed the bottom drain that would drain back to the block with a drain **** to just drain it out manually. Also i made the I made a "T" so that both holes on the back of the block feed to one port on the catch can and the top port I used for the valve cover breather. Thats it and your done.
Old Feb 17, 2004 | 03:27 PM
cooljerk187's Avatar
pcv to catch can to IM, dont plug ur IM hole bc that is where the PCV valve gets the vacuum to open up.
Old Feb 17, 2004 | 03:37 PM
beepy's Avatar
Default Re: (cooljerk187)
Question: Is it a good idea to, rather than use a catch can, simply route the vacuum half of the PCV system to the vacuum side of the turbo and vent the other to atmosphere?
The location between the filter and the inlet of the turbo is always under vacuum, whether it is the cylinders creating vacuum or the compressor. The standard location for a PCV hose (below the throttle blade) is under vacuum when the throttle is closed and under boost when the throttle is open. This tends to pull large amounts of oil in with it, since the PCV valve remains open while the differential built up in the crankcase relieves itself.
The catch can tries to simply retrieve this oil, but it still doesn't do anything about the cause of the oiling.
This is a basic drawing of what I am talking about:
Modified by beepy at 1:10 AM 2/18/2004
m0squ1t0
Sep 6, 2009 10:00 PM
lv6l
Jan 14, 2006 09:08 AM
Tad
Nov 1, 2004 12:06 PM
dingusjt
25
Nov 18, 2002 05:37 PM
fred92htch
Sep 9, 2002 04:24 PM
