Helicoil gone bad!
Old Jun 15, 2004 | 08:30 AM
rocket256's Avatar
Default Helicoil gone bad!
About a week ago I got my car back from the shop. Everything was good. All of a sutton after drive it for about 400 mile over a course of two days I smelt antifreeze and seen white smoke . I take it back to the shop they say the head gasket went. But after they took every thing apart; one of the helicoils in the block come up. They say from high boost!
What should I do? Help me out!
Old Jun 15, 2004 | 08:38 AM
tgreaves's Avatar
Default Re: Helicoil gone bad! (rocket256)
Did you have a head bolt hole helicoiled?
Old Jun 15, 2004 | 08:41 AM
rocket256's Avatar
Default Re: Helicoil gone bad! (tgreaves)
Yes.
Old Jun 15, 2004 | 09:20 AM
tgreaves's Avatar
Hmm.. Not too sure on that one then.. Maybe you could jump up to a bigger head bolt and just get the block retapped and the hole in the head opened up..
Who put the helicoil into the block?
Old Jun 15, 2004 | 09:29 AM
ek9vboi2's Avatar
same problem my buddy has. he just tapped bigger holes, but when he was putting it bak together he stripped a few more so becareful
Old Jun 15, 2004 | 09:37 AM
bruthaboost's Avatar
Go with time-serts. You are going to have to be careful about drilling the block. If you don't have a heavy duty drill press I'd have a machine shop do it. With the time serts you'll need to have "lip" for the time-sert to sit on. They will not back out on you. Honestly for the money you might be better off with another block. A time-sert set is around 55.00 plus the machine work. A bare block plus machining may be cheaper.
HTH
Old Jun 15, 2004 | 11:24 AM
turbohondask's Avatar
Default Re: Helicoil gone bad! (bruthaboost)
time sert I second that
Old Jun 15, 2004 | 04:31 PM
rocket256's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruthaboost &raquo;</TD></TR><TR><TD CLASS="quote">Go with time-serts. You are going to have to be careful about drilling the block. If you don't have a heavy duty drill press I'd have a machine shop do it. With the time serts you'll need to have "lip" for the time-sert to sit on. They will not back out on you. Honestly for the money you might be better off with another block. A time-sert set is around 55.00 plus the machine work. A bare block plus machining may be cheaper.
HTH</TD></TR></TABLE>
That is cool but my block is built!
Old Jun 15, 2004 | 05:35 PM
BigMoose's Avatar
There was a great timesert how to do it post about 9 months or so posted. It had great info and pics of the entire process. It is worth looking for.
Old Jun 15, 2004 | 05:44 PM
rocket256's Avatar
Default Re: Helicoil gone bad! (BigMoose)
Thanks! Ill try to find it!
willard steen
Apr 5, 2016 12:22 AM
homoaranea
Sep 5, 2013 12:38 AM
sonofsam
Nov 7, 2005 08:26 AM
