any thoughts on this wideband o2 reader?
Old Jun 14, 2004 | 10:10 AM
igo4bmx's Avatar
Default any thoughts on this wideband o2 reader?
its very affordable at around 90 bucks and all i would need is a wideband 4 wire vx or hx o2 correct?
Old Jun 14, 2004 | 10:41 AM
SL0WEGG's Avatar
Default Re: any thoughts on this wideband o2 reader? (igo4bmx)
i believe they are 5 wire
Old Jun 14, 2004 | 11:16 AM
mos's Avatar
mos
Default Re: any thoughts on this wideband o2 reader? (boostedej1)
I think that is for a narrowband? Widebands usually require a control box in addition to a meter.
Old Jun 14, 2004 | 11:25 AM
igo4bmx's Avatar
Default Re: any thoughts on this wideband o2 reader? (mos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mos &raquo;</TD></TR><TR><TD CLASS="quote">I think that is for a narrowband? Widebands usually require a control box in addition to a meter. </TD></TR></TABLE>
oh really?
Old Jun 21, 2004 | 02:33 AM
96dc2's Avatar
Wideband O2 sensors are 5-wire and you need more than the meter. You need the controller. Search for "wideband" you'll find info, easily.
Old Jun 21, 2004 | 05:54 AM
rice4life's Avatar
it says lambda meter on it, which means wideband. do you have a link to this product?
Old Jun 21, 2004 | 06:25 AM
spoolinlude's Avatar
I live under a rock
Default Re: any thoughts on this wideband o2 reader? (rice4life)
thats not correct, lambda is simply a unit of measure in electronics.
Narrow and wide band O2 readouts can both readout in lambda... if i'm not mistaken you can actually buy the autometer gauge in lambda.... why you'd want that i don't know.... that unit is definatly not wideband, a friend has it on his mustang.. not wideband
Old Jun 21, 2004 | 07:34 AM
integra-modder's Avatar
Default Re: any thoughts on this wideband o2 reader? (spoolinlude)
it looks like its just a display....
If you have a wideband, it should display the proper af, but should not be used without a wideband.
Old Jun 21, 2004 | 09:12 AM
Bailhatch's Avatar
Default Re: any thoughts on this wideband o2 reader? (integra-modder)
one issue would be that the display is calibrated for 0-1 volt while most wideband controlers output is 0-5v.
you would still need to have a way to control the sensor like the diy-wb board. that is your biggest problem.
your best best is to save up 3 bills and get the PLX m300 IMO
Old Jun 21, 2004 | 09:24 AM
dsadas89das78934's Avatar
i too am pretty sure thats not wideband... we had an AF monitor that looked just like that on our formula SAE car, and it did not have a wideband
Old Jun 21, 2004 | 09:28 AM
crxirex's Avatar
Default Re: (soccaian)
The thing sucks don't buy it. My friends have tryed them, and we use them as hockey pucks now, because thats about whaty ou get a 90 dollar hockey puck.
Junk!
Old Jun 21, 2004 | 05:46 PM
Default Re: any thoughts on this wideband o2 reader? (Bailhatch)
I have an AEM wideband which outputs both a 0-1 and a 0-5. Both are wideband signals its just the 0-5 has 5 times the divisions for its display, good to the hundredths place.
finest_GSR
Apr 28, 2006 12:53 PM
Adam.
Jan 20, 2005 07:03 AM
calvarez
Jun 7, 2004 09:25 PM
JDMlyfestyle
Mar 30, 2004 09:48 AM
b18cx
Dec 4, 2002 04:23 AM
