ACL bearing help?? please
Old Jun 13, 2004 | 04:04 PM
turboex's Avatar
Default ACL bearing help?? please
Ok ACL's are one size fits all for the most part i hear, but in honda world what color bearing would be one size smaller (tighter clearance) that ACL's thanks This is for a gen1 b16 rod bearing. thanks again
Old Jun 14, 2004 | 12:21 AM
AbaZ's Avatar
Default Re: ACL bearing help?? please (turboex)
ACL 1 size fits all..
lol, thats why I use factory bearings
Old Jun 14, 2004 | 08:18 AM
RyanEJ8's Avatar
Default Re: ACL bearing help?? please (AbaZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbaZ &raquo;</TD></TR><TR><TD CLASS="quote">ACL 1 size fits all..
ACLs are actually good bearings. A better choice over OEM in my opinion, especially because of the price.
Read what earl has to say about ACLs in this thread.
https://honda-tech.com/zerothread?id=628073
Old Jun 14, 2004 | 08:43 AM
AbaZ's Avatar
let me rephrase that.. I have actually used ACL bearings and have had no problems with them, but I PREFER using factory bearings. I get my mains and rods right on .0015 and sometimes that requires 2 different color bearings.
Example, engines I just really dont care about, I just slap in some cheap ACL bearings, and with ones I care about I use factory bearings.
Jeff
Old Jun 14, 2004 | 08:44 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbaZ &raquo;</TD></TR><TR><TD CLASS="quote">lol, thats why I use factory bearings</TD></TR></TABLE>What is your actual clearance after you install your honda bearings?
Old Jun 14, 2004 | 09:19 AM
AbaZ's Avatar
Default Re: ACL bearing help?? please (earl)
Earl you can debat all day long about ACL bearings and I could careless,
I come out about .0015 - .0017 everytime, at times it does suck that I have to buy a bunch of different combanations of bearings and some I dont even use, then have to go back to the dealer and re-order some more bearings. But I'm getting a nice little collection.
Old Jun 14, 2004 | 12:43 PM
RyanEJ8's Avatar
What makes you so sure that stock clearances are best for a not stock engine?
As earl has said before, only Honda uses the color coded bearing system, every other car manufacturer gets by fine without it.
Old Jun 14, 2004 | 01:07 PM
AbaZ's Avatar
Default Re: ACL bearing help?? please (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">What makes you so sure that stock clearances are best for a not stock engine?
As earl has said before, only Honda uses the color coded bearing system, every other car manufacturer gets by fine without it.</TD></TR></TABLE>
Because I know what works ? I havent been doing this **** for the past 5 years for nothing.
And Honda is not the only one who uses it, lets try Nissan/Infinity/Mitsubishi but the really good manufactors like Kia and Hyndai use the good ol 1 size fits all.
Old Jun 14, 2004 | 01:27 PM
dasher's Avatar
OEM for the true hardcore builder who fully blueprints his engine with a dial bore guage and micrometer.....
ACl for the average person who wants to save 120 bucks and get a good set of bearings he can check with plastiguage. If one of them is off he can stop by honda and buy the bearing halfs individually at 12 bucks a peice...
The last engine I built was a H22a .... the block asked for all greens on the mains but was stamped wrong .... Turns out that I had to get a brown for # 3 because the acl was way to loose ...
Important point in Engine building --- NEVER Assume anything ! tripple check all your measurements.
s2kkid
Jan 16, 2005 08:37 PM
bunnyrabbit
Mar 29, 2004 05:20 AM
sir2k
Mar 5, 2003 11:33 PM
1.8T_EG
Feb 19, 2003 06:55 PM
