Do i need both turbo timer and boost controller?
Old Jun 15, 2004 | 10:29 PM
brasilstreet's Avatar
Default Do i need both turbo timer and boost controller?
I was wondering b/c i think i only need the boost controler but just want to be sure?
Old Jun 15, 2004 | 10:31 PM
GSRrR's Avatar
Default Re: Do i need both turbo timer and boost controller? (brasilstreet)
if you do not know the answer, do not even get the boost controller. do you even know what each are for? i hate to see you blow your motor because the boost is set too high.
btw. you do not NEED a timer or a boost controller.
Old Jun 15, 2004 | 10:34 PM
DA9-T's Avatar
Just get the turbo timer to keep your turbo happy.
P.S. You dont need the boost controller unless the spring in your wg is too low or high for your desired psi.
Old Jun 15, 2004 | 10:40 PM
Ok well what if im at 8psi and my wastegate is 7-15 psi do i have to worry or no and i know the difference and what they do but i also thought the turbo controler would time it aswell but never mind . So your ^ saying if i have 8 psi with a wastegate with 7-15 psi i dont need the controler . But i will get the controller but im still saving after the turbo manifold and down pipe im buying.
Old Jun 15, 2004 | 10:44 PM
GSRrR's Avatar
Default Re: Do i need both turbo timer and boost controller? (DA9-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9-T &raquo;</TD></TR><TR><TD CLASS="quote">Just get the turbo timer to keep your turbo happy.
huh? boost controllers do not LOWER pressure. it can only raise it.
brasilstreet - please search and read more of the FL archives. lots of useful info there. you can just sit in your car for a minute to cool it down if you do not want a timer. i do not understand "if im at 8psi and my wastegate is 7-15 psi "
Old Jun 15, 2004 | 10:52 PM
i just said that because DA9-t said something about if my psi is too low and or too high something . Lol well just for get i said that so yea im going to read alitle more on the boost controlers. But can you please explain to me what the boost controler really does so i get some knowledge about it in my head?
Old Jun 16, 2004 | 12:29 PM
mike1114's Avatar
Default Re: (brasilstreet)
brasilstreet.
A boost controller changes the amout of boost.
A wastegate spring is set for one pressure, not from say x to y. Most likely your spring is set around 7psi. This means you CANNOT go lower than 7psi. IF you would like to go higher, then you use a boost controller, to raise the psi to what you want it to be.
A turbo timer keeps your car running for about a minute after you turn the car off, this way, the oil in the turbo has a moment to cool down as it is bad for hot oil to sit in your turbo.
I can tell from your questions, you are new to the turbo/car modifying world, learn how to use the search function on this website and use it to search out all the questions you have before asking, because most likely, someone like yourself has already asked that same question. IF you don't find out what your looking for, then you post.
There is a lot to learn about the turbo world, please read up before you make an attempt. READ THESE TWO SITES OVER AND OVER AND OVER......these two sites have all the basic info you need to know.
http://www.cse.uconn.edu/~yele....html
https://honda-tech.com/zerothread?id=268110
Old Jun 16, 2004 | 12:30 PM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brasilstreet &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering b/c i think i only need the boost controler but just want to be sure?</TD></TR></TABLE>
You do not NEED either, but both of them are neat if you want to spend money.
Old Jun 16, 2004 | 12:36 PM
DaX's Avatar
DaX
Loved
Community Favorite
I say save the money you'd spend on a turbo timer and put it elsewhere. Most of the time you can spare a minute while you sit there and let your car idle before shutting it off.
Old Jun 16, 2004 | 01:38 PM
Deluzional's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">I say save the money you'd spend on a turbo timer and put it elsewhere. Most of the time you can spare a minute while you sit there and let your car idle before shutting it off.</TD></TR></TABLE>
Yea seriously, is 5-6 mins a day worth 70-80 bucks? Id rather spend it elsewhere
Old Jun 16, 2004 | 01:41 PM
RobbieG35's Avatar
12 Years Strong
Default Re: (DaX)
Screw that, in a hot *** car with no A/C I love to get out a minute early, I would get a turbo timer
Old Jun 16, 2004 | 01:47 PM
Deluzional's Avatar
Default Re: (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">
Well here in nor cal, the weather hasnt been too overwhelming, I can survive
Old Jun 16, 2004 | 01:50 PM
Stu's Avatar
Stu
New User
Why can't you just stop driving like an ******* about a minute before you get where ever you are going? That's what I do.
Old Jun 16, 2004 | 02:21 PM
ALright thanks people yea i learned that i dont need either turbo timer or controller and i wont be getting the controller for now .Ill just get a turbo timer because this guy i know is selling one for good price 45 bucks and i seen the picture its in perfect condition.But yeah i am new to turbo i've been learning with people around my area who have boosted cars and i've been asking questions ive learned alot but now im aiming to learning more about the tuning of hondata and how it works etc. I will read up on more thanks for the help again.
bodea_florian
Aug 25, 2004 06:54 PM
smallttocs
Feb 22, 2003 09:47 AM
simike
May 10, 2002 03:01 PM
Snafu-Si
Mar 5, 2002 02:07 AM
LEON
Aug 30, 2001 02:07 PM
