how do I upgrade my T25????
Old Jun 12, 2004 | 08:01 PM
solsi2000's Avatar
Default how do I upgrade my T25????
hey guys these are probably stupid questions but ive done my research and i was told this is a pretty good educated bored. so would anyone know what upgrades I can do with my t25? because t25's are really small and I want to raise my hp above 200 so I want to go with a t3... what would I need to do? just weld new t3 flanges on everything iguess? anyone know anything about t28s? any difference? thanks for the help with being a noob on here.
Old Jun 12, 2004 | 08:21 PM
Casey's Avatar
Default Re: how do I upgrade my T25???? (solsi2000)
if its a mitsubishi t25 just get a turbo upgrade for a 2nd gen eclipse thats a direct bolt on. t28 is a good choice. a forced performance big28 made 255/265 at 16psi on my friends eclipse and spooled as quick as the stock t25, so they can definitly make some power
Old Jun 12, 2004 | 09:27 PM
Bailhatch's Avatar
Default Re: how do I upgrade my T25???? (Casey)
from my experiences I hate the peaky feel of a t25 turbine wheel on a honda motor. Since a t28 is a t25 turbine mated to a t3 compressor I would not even bother. Swapping to a straight t3 is a good idea. A used t3 capable of supporting 200whp is not hard to find for under $100. A 50trim off a saab or volvo is easy to find for cheap. I have one with a .63 a/r turbine housing so it has great top end but spools to 10psi at 3200rpm on a stock d16. $.02
Old Jun 13, 2004 | 08:19 PM
solsi2000's Avatar
Default Re: how do I upgrade my T25???? (Bailhatch)
so would it be possible to run the t25 for now then after I get sick of it I can convert to a t3? How much work is involved and is it even worth it? thanks for your opinions guys. peace
Old Jul 4, 2004 | 05:51 PM
BME1986's Avatar
bump cuz i am looking for the same info.
Old Jul 4, 2004 | 06:09 PM
T-RO's Avatar
youll need a new manifold or adapter plate if you switch from T25 to T3.
grkblood13
Feb 16, 2009 10:48 AM
big-cat
May 11, 2006 10:30 AM
integracivic94
Oct 17, 2004 09:19 AM
egturbo
Apr 8, 2004 08:37 AM
turboEF ZC
Oct 25, 2001 02:47 PM
