leakdown:difference between cold and warm
Old Jun 13, 2004 | 07:29 PM
servion's Avatar
Default leakdown:difference between cold and warm
I did some damage to my motor on the dyno last weekend, and I got a chance to run a leakdown test.
The motor was completely cold when the test was ran, and I came up with 10% 10% 15% 10%
Here's my setup: benson sleeved b18c, 9:1 cp pistons, stock bore. Stock GSR head, full-race t3/t67
I pulled the head today and put gas in the combustion chambers... the one cylinder with the 15% leakdown had gas running out of one of the exhaust valves.
I know that running a leakdown and compression test will yield higher numbers on a warm motor, because the rings have had a cahnce to expand due to the heat. My question is: how much better will a leakdown test be with a warm motor over a cold motor? Will a 10% leakdown across the board be acceptable on a completely cold motor such as mine?
Old Jun 13, 2004 | 08:18 PM
99B16Si's Avatar
those numbers dont sound too bad for a cold motor at all, especially on a built one thats gonn have a lot more clearance than atightly sealed stock one
Stewie's Avatar
Default Re: leakdown:difference between cold and warm (servion)
I think warming up the motor will help the exhaust valves to seal more than it help the rings. A 10% leak is good or bad depending on where the leak is occuring. You can have a 20% leak out the exh valves and the car will still run fine. However if you losing 6% out the rings the motor is shot and it won't run well.
Old Jun 14, 2004 | 08:33 AM
servion's Avatar
Default Re: leakdown:difference between cold and warm (Family Guy)
Any thoughts on how much the values will be affected in a hot vs cold motor?
Old Jun 14, 2004 | 11:51 AM
servion's Avatar
Anyone?
Old Jun 15, 2004 | 05:16 AM
servion's Avatar
boosted-hybrid: "I always comp test engines hot and leakdown test engines cold. The leakdown test does not vary significantly when the engine is warm. It's a shame that you didn't let the engine go up to full heat and then do the leakdown test. The leakdown would change maybe 1-2%. "
mynameizstitch
May 19, 2009 07:52 AM
blackeg
Jan 20, 2009 03:56 PM
realis9
46
Jun 25, 2008 12:25 AM
NA JDM GSR
26
Dec 28, 2006 10:47 PM
blackeg
Oct 7, 2006 05:53 AM
