Civic 96-00 ek turbo piping routing HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
this is my car i want to see how u guys are routing ur turbo piping on dohc motor swaps in ur cars please post all u can i think i did mine wrong let me know k
Re: Civic 96-00 ek turbo piping routing HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (hulkhb)
i would like to see others that why io ask also to see how the way others have it done too it may be better there way that why i would like to see thanks for the replys though
Re: Civic 96-00 ek turbo piping routing HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (buck02)
The same...
But I gotta upgrade mine to solid smooth bends not my patchy 6000 little peice i got going on underneath..lol
Re: (Teglove2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglove2 »</TD></TR><TR><TD CLASS="quote">WOW! Nice set-ups guys! Give me some details on those set-ups please</TD></TR></TABLE>
more pics there so good of the piping please
Re: (h22 civic)
i had the same problem with the same setup. here's what i did.
clock the turbo so that the compressor outlet points up towards the front of the car. then get a 180 degree pipe, cut the pipe in half and use one 90 dgree on the turbo part and the othe half to the hole where the windsheid washer bottle use to be. i see that you still got ac so that might not work, just a suggestion though.
Did any of yall have to cut the hole out so the piping would go into the bumper area. The pipe from the throttle body to the cooler? Looks like I will be hacking stuff up
Re: Civic 96-00 ek turbo piping routing HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (97hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb »</TD></TR><TR><TD CLASS="quote">Did any of yall have to cut the hole out so the piping would go into the bumper area. The pipe from the throttle body to the cooler? Looks like I will be hacking stuff up </TD></TR></TABLE>
I looked at the first pic and it CLOSELY resembles what my SOHC looks like as far as TB to IC piping. I didnt have to do any cutting to get the piping in. 2000 coupe
Re: Civic 96-00 ek turbo piping routing HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (specv5150)
i did hve to take a hole saw and cut a hle for the piping but i need to make it bigger it cratches on the edge of the sheet metal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buck02 »</TD></TR><TR><TD CLASS="quote">i did hve to take a hole saw and cut a hle for the piping but i need to make it bigger it cratches on the edge of the sheet metal </TD></TR></TABLE>
REALLY???
What size piping is it. my hole where the intake resonator was still leaves me at least an 1 1/2" - 2" to work with as far as piping diameter.
REALLY???
Wow, I've never seen so many turbo H22 civics in one place. Here's how I routed mine:
Compressor outlet points down towards the ground. I have a 90 degree silicone elbow and a u-shaped pipe that comes around into the intercooler.
It comes out of the intercooler and through the hole in the fender to the TB. FYI, 96-00 hatchbacks did not have this hole. I had the body shop use a coupe inner fender after some guy ran a red and hit me.
Tyler
Tyler
Re: Civic 96-00 ek turbo piping routing HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (Tyler H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler H »</TD></TR><TR><TD CLASS="quote">
with the bumper support cover 1/3 of the intercooler, does that cause it to not work to its full potential?
Re: Civic 96-00 ek turbo piping routing HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (AL ASPIRATED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyler H »</TD></TR><TR><TD CLASS="quote">Wow, I've never seen so many turbo H22 civics in one place. Here's how I routed mine:
Tyler
who built that intercooler piping for ya or is that a t kit i like that lot it looks so clean is it cromed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 »</TD></TR><TR><TD CLASS="quote">
REALLY???
What size piping is it. my hole where the intake resonator was still leaves me at least an 1 1/2" - 2" to work with as far as piping diameter.</TD></TR></TABLE>
its 2.5 piping but the hole of course is like 3 inch
Tyler
REALLY???
It's not chromed, just polished aluminum. I made it myself. Thanks for the compliment.
Tyler
Tyler
mmk21
05-13-2008 06:28 PM
IOSUA
12-02-2007 06:41 PM
