400hp----->SC34 or T3/T04e?
This is for my 97 GSR. I have 10:1 JE pistons at 81mm, Eagle Rods and stock sleeves. Everything else is stock. I daily drive this car and occasionally take it out on the road course...What's going to spool better/faster and make 400hp? the SC34 is from a Revhard Stage 2 kit and the T3/T04e is a Turbonetics(Compressor .50 A/R .57 trim, turbine Stage 3 .63 A/R).
Moderator in Chief
Re: 400hp----->SC34 or T3/T04e? (jonnybravo)
Which SC34 comes with the Revhard Stage 2 kit? Is it the .63 AR or the .48? Since all other specs are the same, the one with the smallest AR will spool the fastest.
The SC34-B (T3/T04B) with the .48 AR would get you exactly where you want IMO.
Or even a smaller SC32 or SC50 too. Even the small SC50 is rated up to 450hp by PTE.
http://www.precisionte.com/sportcompact.php
Re: 400hp----->SC34 or T3/T04e? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Which SC34 comes with the Revhard Stage 2 kit? </TD></TR></TABLE>
I'm actually not sure... This is the one I was asking about...
https://honda-tech.com/zerothread?id=891844
Moderator in Chief
It doesnt really say. I think its the SC34-E (.63 AR). Thats what I got with my Revhard 2C kit but I cant remember if I had to request that or not. But just call up Revhard and ask em what turbo they use in their off the shelf stage 2C kits.
Re: 400hp----->SC34 or T3/T04e? (Reilly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reilly »</TD></TR><TR><TD CLASS="quote">hp or whp?</TD></TR></TABLE>
whp...
whp...
sh!t happens.
Re: (11SECEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11SECEG »</TD></TR><TR><TD CLASS="quote">mine pushed out 350 hp @14 lbs revhard 2c kit... pump gas... gsr 81mm, 9.8 c/r</TD></TR></TABLE>
you have a sc34?
you have a sc34?
I get full boost at about 3700-3800rpms with mine, Rev Hard log, 63 A/R When motor was stock. I'll let you know in a couple weeks what it does with a 2.0 9.5:1 built motor in a couple weeks.
I can't speak for the other, I have only had a "b" turbonetic before.
Modified by Reilly at 6:20 PM 6/15/2004
Re: 400hp----->SC34 or T3/T04e? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">isn't the sc34 (maybe its the sc32 ) a t3/to4e 57 trim anyways? </TD></TR></TABLE>
yes
yes
Re: 400hp----->SC34 or T3/T04e? (Mad Chemist)
So will they be the same or should I pick one over the other? Any advantages/disadvantages between each of them?
underpressure02
10-29-2003 06:47 AM
