!!!!!!!!!Another stock GSR dyno!!!!!!!!!!
Old Jun 15, 2004 | 09:06 PM
tegedrex's Avatar
Default !!!!!!!!!Another stock GSR dyno!!!!!!!!!!
Well Ill go through the setup first off
B18C1(stock)
Arp headstuds
Full Race turbo kit
ITS 60-1 Turbo
HP racing sheet metal IM
Hondata S200b
First run was on 5.5 psi/final run was at about 9.5psi/ran into a problem getting the boost cont. so I had to use a couple of t's
Elevation is at 5800ish ft, however dyno is SAE corrected
Please feel free to ask ?'s and comment
Also would like to thank Geoff @ Full Race, Boosted Hybrid, and Mase.
Old Jun 15, 2004 | 09:07 PM
tegedrex's Avatar
Default Re: !!!!!!!!!Another stock GSR dyno!!!!!!!!!! (tegedrex)
wow thats huge can someone resize
Old Jun 15, 2004 | 09:08 PM
rondigs's Avatar
Resize would help. Nice power though
Old Jun 15, 2004 | 09:32 PM
Pengo's Avatar
Default Re: !!!!!!!!!Another stock GSR dyno!!!!!!!!!! (rondigs)
wow i need a few more monitors for this....
numbers i saw look nice tho. hard to see the "big picture" tho. can't get enough on the screen at a time to get an overall idea.
nice anyway
Old Jun 15, 2004 | 09:45 PM
TheShodan's Avatar
Moderator
Not too bad, but looks really laggy. even with your high stock compression, spool doesn't really get in good to damn near 5000rpms. But I guess it depends upon what you're trying to do with the car.
Otherwise, very impressive Peak numbers.
Old Jun 15, 2004 | 10:27 PM
hulkhb's Avatar
Default Re: (TheShodan)
I have the garret version of the 60-1 i bought from fullrace. Since mine is on a c5 it spools a little sooner, 4500-4600prms, but with a high revving motor and a short geared tranny a larger turbo like that doesn't seem too laggy at all.
Nice numbers though man. what injectors ?
Old Jun 15, 2004 | 10:35 PM
Mr. Softee's Avatar
Default Re: (hulkhb)
keep revvin
Old Jun 15, 2004 | 10:49 PM
tegedrex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulkhb &raquo;</TD></TR><TR><TD CLASS="quote"> what injectors ?</TD></TR></TABLE>
Holley 75lbs
Old Jun 16, 2004 | 12:21 AM
DD_JonnyLee's Avatar
Default Re: (tegedrex)
nice numbers, is that my old hp mani????, my name used to be trbogsr
Old Jun 16, 2004 | 03:15 AM
ekb18c's Avatar
nice power..
Old Jun 16, 2004 | 04:16 AM
jeremy.'s Avatar
Default Re: !!!!!!!!!Another stock GSR dyno!!!!!!!!!! (ekb18c)
defintely nice numbers out of a stock block...any plans on building the block?
Old Jun 16, 2004 | 05:41 AM
tegedrex's Avatar
Default Re: (Raped-Ape)
Yep thats your old IM, thanks again
As far as plans go going to try and up the boost a bit more and hit 350 or so wheel and then just have fun till it blows, and then the fun will really begin..
Old Jun 16, 2004 | 05:54 AM
G
sh!t happens.
those are good numbers for stock motor.. how does it fill on the highway?
Old Jun 16, 2004 | 06:07 AM
Turbocivic94's Avatar
Default Re: (G"UNIT)
Good numbers
Do u have one of these
Old Jun 16, 2004 | 06:46 AM
Blown90hatcH's Avatar
Old Jun 16, 2004 | 06:52 AM
Skip01's Avatar
So is that 272hp on 5.5psi?
That crazy if it is.Good #s all around.
Old Jun 16, 2004 | 06:58 AM
AspectIndustries's Avatar
Default Re: (Skip01)
o_O Looks good! Hope my goals are meet around that area.
Old Jun 16, 2004 | 07:42 AM
hulkhb's Avatar
post some pics of the ride/setup
Old Jun 16, 2004 | 08:47 AM
turbo-ek's Avatar
nice numbers
Old Jun 16, 2004 | 08:49 AM
dunkd's Avatar
similiar to my old setup (stock gsr, t3/60-1, hondata, 9psi and 294whp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Elevation is at 5800ish ft, however dyno is SAE corrected</TD></TR></TABLE>
and how accurate is that correction?
Old Jun 16, 2004 | 09:22 AM
tegedrex's Avatar
Default Re: (dunkd)
I believe that is the exact same turbo, does it have a blue shield behind the comp. housing.
I will have more pics later today.
As far as the SAE correction Im not sure how accurate that is, but not sure how bad it could be off(do you have any further info on ele. accuracy)..
Ohhh and yes it was the 272 at 5.5psi, at that point I had a huge smile on my face..
Old Jun 16, 2004 | 09:26 AM
MachAF's Avatar
very nice numbers!! very high.
Old Jun 16, 2004 | 09:48 AM
ooairewreckoo's Avatar
Default Re: (MachAF)
thats alotta power on 5.5 lbs.
Old Jun 16, 2004 | 10:02 AM
hulkhb's Avatar
Default Re: (ooairewreckoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ooairewreckoo &raquo;</TD></TR><TR><TD CLASS="quote">thats alotta power on 5.5 lbs. </TD></TR></TABLE>
indeed
Old Jun 16, 2004 | 10:10 AM
red1997civic's Avatar
sweet numbers man!
