can i use this downpipe with this manifold?
Old Jun 13, 2004 | 04:38 PM
egturbo's Avatar
Default can i use this downpipe with this manifold?
hello i was wondering if i can use this downpipe that was with the rev hard manifold with the tubular manifold? TIA
old manifold
new manifold
Old Jun 13, 2004 | 04:40 PM
B18Flip's Avatar
Default Re: can i use this downpipe with this manifold? (egturbo)
you might need to mod it a bit, the turbo placement looks similar on the two manifolds. But i'm sure they're not 100% the same
Old Jun 13, 2004 | 05:07 PM
hulkhb's Avatar
Default Re: can i use this downpipe with this manifold? (B18Flip)
wow what an upgrade on the manifold
Old Jun 13, 2004 | 05:09 PM
B18C1CYA's Avatar
Default Re: can i use this downpipe with this manifold? (hulkhb)
i dont want to be an *** but i wouldnt even consider that an upgrade more like a downgrade
Old Jun 13, 2004 | 05:11 PM
egturbo's Avatar
Default Re: can i use this downpipe with this manifold? (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">i dont want to be an *** but i wouldnt even consider that an upgrade more like a downgrade </TD></TR></TABLE>
really? y? the wastegate placement is better on the tubular one isnt it? and the runners on the rev hard manifold is pretty small its the old school rev hard mani.
Old Jun 13, 2004 | 05:14 PM
B18C1CYA's Avatar
the tubing is realy thin and it will crack and the wastegate most likely will crack off , they are made of thin garbage tubing that cant suport the wieght of the turbo or even the wastegate, stay with the revhard way better
Old Jun 13, 2004 | 05:20 PM
egturbo's Avatar
im only gettin the tubular one for $75 looks like the one i used on my ls turbo and mine held very nice. the guy said its not ssautochrome and mine wasnt either. mine never cracked at 10 psi.
Old Jun 13, 2004 | 07:06 PM
egturbo's Avatar
what do u guyz think?
Karsten
Jul 19, 2018 12:06 PM
lsvsol
May 14, 2006 06:35 AM
project dc2
Mar 29, 2004 10:05 AM
simike
Jul 20, 2002 09:32 AM
