Ignition tuning
Old Jun 13, 2004 | 07:46 PM
ZhaGg's Avatar
Default Ignition tuning
I've checked some of the archived threads for this, but I'm still confused.
When tuning ignition maps (on my Zdyne for instance) what can I do to make sure I don't go too advanced? One of the threads mentioned advancing the timing until I see a loss in power on the dyno. That sounds sorta dangerous. I may be ignorant or something, but I thought that if I was advanced enough to see a loss in power, that I'd be stressing the hell out of the bottom-end. Anyway, let me know what you guys think. Also, any info. on the J&S Safegaurd would be welcome as well. BTW, any other aftermarket knock detection devices out there for me?
Old Jun 13, 2004 | 11:47 PM
mgro's Avatar
Default Re: Ignition tuning (ZhaGg)
I've got a J&S. So far, I've been tuning piggyback style- AFC for fuel, J&S for boost retard. What I used to do was advance the boost retard until the knock indicator light on the J&S starts to light up just a little. Although its probably better then advancing until the power drops off, I still think its pretty crude.
I use Crome now, so I can change the ignition maps themselves. Perhaps EGT measurements may help, in addition to AFR and power? Question is, what values we should aim for?
Mark.
Old Jun 14, 2004 | 09:53 AM
ZhaGg's Avatar
Default Re: Ignition tuning (mgro)
Yeah, I'm not sure what I'm really supposed to be looking for. I want reliable power and I'm pretty sure that the ignition tune that came with the ECU is pretty conservative. The guys at the dyno shops I've been to just have answers for AFR. When it comes to timing, it seems like it's hit or miss. Anyone know how to come up with decent timing maps?
Old Jun 14, 2004 | 12:13 PM
Muckman's Avatar
Moderator in Chief
The Knock sensor will give you tell you if are running too much timing. If you dont have a way to monitor this then the J&S is your best bet. And when on the dyno I believe you will see power start to drop off before you endanger anything, just advance it a little at a time. Once you find the MBT (Max Brake Torque) or peak power its a good idea to back off a degree for safety.
http://www.boosted-hybrid.com/viewtopic.php?t=200
booboo782
Engine Management and Tuning
Sep 3, 2015 08:28 AM
ohsnapzafingcu
17
Jul 16, 2010 04:41 PM
birz
Jun 18, 2004 08:22 PM
7rrivera7
May 14, 2003 08:28 AM
falcongsr
Aug 8, 2002 12:51 PM
